1949 B crankshaft and bearings
ronhf
05-15-2008 09:29:13
I have a 1949 B that I had to replace the crankshaft and flywheel because the splines were messed up bad. All of the journals on the used crank that I got look good (standard size and max out of round of 0.0008 on the rod and 0.0002 on the mains), except for one spot on the crank that has a spot about half the size of a dime that is a little rough. The spot is near where the seal is on the flywheel side.
Do you think I would have any trouble just using the crank as is?
Mike M
05-15-2008 12:01:32
 Re: 1949 B crankshaft and bearings in reply to ronhf, 05-15-2008 09:29:13
I wouldn't worry about that spot for the seal as it is just a packing that goes into a slinger and it is stationary on the crank. Sometimes I use a trace of silicone on that packing to help it slide on and then seals it in place. You just have to have everything ready to go and assemble it and set the end play before it dries competely. And if you have your decimals in the correct spot and using inches ? all your figures are less than .001" and I'm guessing that is well within the tolerances in the JD manual which I hope you have a copy of as it is GREAT.
Hoss in Me
05-15-2008 10:24:51
I would think you could get a speedie sleeve for it.Ask at your local NAPA dealer or machine shop. Hoss
ronhf
05-15-2008 12:04:16
 Re: 1949 B crankshaft and bearings in reply to Hoss in Me, 05-15-2008 10:24:51
Thanks Hoss, but the area I am concerened about is where the bearing rides; not the seal. I would rather not get the vrank ground unless its absolutely necessary.
