1946 B w/ Wico C magneto - removal?!?
Euge
05-14-2008 21:44:40
Want to pull the Wico model C magneto off a '46 B because the timing is Way off; hard to start, backfiring, etc.. Want to be able to turn mag CCW as per manual, to verify spark and then to get it aligned properly.
Do I have to take the mag apart to get at the mounting bolts?!? How is the mag body mounted to the governor case?
Thanks!
johns48jdb
05-15-2008 15:32:14
 Re: 1946 B w/ Wico C magneto - removal?!? in reply to Euge, 05-14-2008 21:44:40
hey alafrog, sonds like you have something real wrong some place. see if you can leave a mesasage for fit or pat browning to help you out. make a seperate post on here and ask for their help.
Euge
05-15-2008 10:01:04
Found my problem. As I suspected, I'm not too bright.
This was originally a dual-fuel tractor.
It was retro-fitted years ago with just one large gas tank.
As the tank sits in the 'forward' position, it's not long enough to rest on the rear gas tank support bracket. So, a makeshift bracket was fashioned.
Long story short, this makeshift bracket was blocking my view of the upper mounting bolt, as this bolt comes from the flywheel side of the governor assembly.
Thanks to all you guys; you're amazing. Without you, us 'new guys' would be S.O.L..
Thanks again!
alabamafrog
05-15-2008 08:36:13
The mag on my 47 A has a bolt in the bottom you can loosen and adjust timing by pivoting the mag. That bolt is on the belt pulley side bottom. There is supposed to be another bolt on the top that goes in from the flywheel side into the back of the mag. That bolt or stud is missing on mine so if I take the bottom bolt out the magneto falls off in my hand. I figured this out yesterday when I was trying to get mine to run. One thing I have noticed is after I finally got it running I could pivot the mag all the way in either direction and could tell little to no difference in the way the tractor ran so I just set it back close to the middle. I got it to run by first fixing the loose rotor button then drying the mag out with a hair dryer.
johns48jdb
05-15-2008 08:22:10
sorry i meant left and tried to correct it but was to late.
johns48jdb
05-15-2008 08:20:40
i was told by a jd mechanic of 50+ years to turn the mag as far to the left as it will go, turn the flywheel where the holes in it are parallel with the ground and then turn mag until it snap[ped and tighten it down there. way i did mine and it starts and runs good. unless you've pulled the plugs wires off and it was running before i can't see why it would back fire unless you have the timing way off. was it running before you did anything to it? if it was and want runnow undo what you did and start over. i hope i'm right on telling you the timing trick. do you agree john t.
johns48jdb
05-15-2008 08:19:36
i was told by a jd mechanic of 50+ years to turn the mag as far to the right as it will go, turn the flywheel where the holes in it are parallel with the ground and then turn mag until it snap[ped and tighten it down there. way i did mine and it starts and runs good. unless you've pulled the plugs wires off and it was running before i can't see why it would back fire unless you have the timing way off. was it running before you did anything to it? if it was and want runnow undo what you did and start over. i hope i'm right on telling you the timing trick. do you agree john t.
Euge
05-15-2008 08:03:59
I can only see the stud (with nut) at the bottom; can't find another mounting bolt anywhere. Definitely not at the top of the unit.
When the nut is loosened the mag pivots like I've read it should, but there's got to be another bolt somewhere?
I have posted 2 pictures at>Link
Thanks again!
John T
05-15-2008 10:14:59
 Re: 1946 B w/ Wico C magneto - removal?!? in reply to Euge, 05-15-2008 08:03:59
The top bolt may simply be missing and thats all there is to it!!!!! !!!!! !!! A stud n nut is in the bottom but on the top theres an open slot in the governor side and the bolt fits through it then screws into the mag. By looking at the outside you dont see the top bolt..... ..... .....
The top n bottom bolts (and the open slot) can only be used to time a ceratin limited amount, again forward CW to retard and backwards CCW to advance and it affects BOTH start n run timing.
If theres sufficient CW CCW adjustment adjust the start impulse timing so the mag SNAPS just when the flywheels Left Hand Impulse LHI passes by the flat mark on the tractors side at 3 o clock. If its too fast the flywheel may kick backwards but if too slow she may not start as well. LHI AT 3 O CLOCK WHEN SHE SNAPS is how you set the start/impulse timing. Then you can use a timing light to see where the run time advance is at.
Its also possible to rough in the start impulse timing by rotating the mag ubtil the plug fires (mag snaps) and then tighten it down but the LHI method I described above is the final n more accurate touch.
I have given Wico C and X Workshop/Seminars and can tell ya how to set BOTH start n run timing but NOT in a short paragraph here other then the very basics above. Post back any questions n dont forget my post above regarding possible 180 out of time and the consequences.
John T
John T
05-15-2008 10:13:32
John T
alabamafrog
05-15-2008 11:42:58
 Re: 1946 B w/ Wico C magneto - removal?!? in reply to John T, 05-15-2008 10:13:32
Hey John T, do you have those detailed timing instructions saved on your computer so you could email me a copy without too much trouble???
John T
05-15-2008 13:09:07
 Re: 1946 B w/ Wico C magneto - removal?!? in reply to alabamafrog, 05-15-2008 11:42:58
Sorry I dont or Id be more then glad to post them. Duane Larson has his instructions saved, you might do a Search for his name and Wico Mag timing etc and find them. Even with his you have to have some basic understanding to follow his plan, he is more exacting them myself n does it a bit different then I do. You have to do all that mag removal and set the lag angle etc etc but this original question may simply need the mag rotated without getting into all that lag angle n other stuff which is how I tried to answer it. Im planning 3 articles for Green Magazine to cover the topic in detail if I ever get at it and this forum isnt for answers that take pages n pages to answer in my opinion.
John T
John T
05-15-2008 05:30:48
Euge, Those 2 top n bottom bolts (mag to governor case) Mike mentioned fer sure will allow its removal, but that may or may not be necessary..... If those same 2 are loosened the mag can be rotated forward CW which retards BOTH the static and start/impulse timing while rotation backwards advances both. If you remove the plugs for easy cranking (have gas off n carb bowl drained to avoid gas into cylinders) and have the plug wires attached n the plugs side grounded (away from plug hole where gas vapors may exit) as you turn the flywheel the mag should SNAP each 180 degrees with every other plug firing each 180 degrees. The start impulse timing should be adjusted so the mag snaps n the left plug fires just as the Left Hand Impulse (LHI) timing mark on the flywheel passes by the flat mark on the tractors side at the 3 o clock position.
If that mag is installed 180 out of time (fits in governior either way) she will pop n bang n backfire n maybe kick the flywheel backwards something awful which a top n bottom plug wire reversal will cure.
I dont have a complete canned Wico C and X timing procedure handy, Duane does I think, it gets a lil complicated if youre not already somewhat familiar with mag operation.
John T
Mike M
05-15-2008 05:08:49
You do not have to take it apart to remove it. There are just 2 bolts go into the back mounting flange. One may be a stud and a nut.
