40U - piston oversize
Glen D Anderson
05-14-2008 20:31:37
What are the largest over-sized pistons that are available that can be safely run in a '54 40U without the cylinder wall becoming too thin?
I've seen ".125 over-size advertised on the website here, is there really that much meat to spare in those blocks??
The reason I ask is this tractor(engine) is getting weak and the last time I had it apart the cylinders were in quite rough shape(excessive wear, out or round, and taper) That was 10 years ago and at the time all it got was a honing and a set of rings. So I know this time I tear it down it's going to be rough, at least ".045 wear I would guess..... ....if I'm lucky.
Thanks in advance,
Glen
buickanddeere
05-17-2008 07:33:56
 Re: 40U - piston oversize in reply to Glen D Anderson, 05-14-2008 20:31:37
Just about everything was an option on those Dubuques so you have to look and check.
The local detroit dealer's parts person gave me the "deer caught in the head lights look" while ordering 2-53 parts. He opened the parts book and it said the 2-53 was obsolete. I suggested he check the 4-53 and it was still current. I ordered what I needed from that listing but the parts guy was positive they wouldn't fit..... ..... ..... ..... .....
There are several past posts here on what needs updating on the two strokes.
d. coleman
05-15-2008 20:39:06
just came back from machine shop where my 48 "M" block is being bored from a worn .040 to .090. several people told me to have cylinder sleeved because JD only offered .020 & .040 over piston. guy in machine shop told me about aftermarket .045, .090, .125, dont know if block can be sleeved after boring to .090. anyway the JD 40 should have the same standard bore as "M". just running off at the mouth. good luck. d. coleman
buickanddeere
05-15-2008 07:39:27
Have you dynoed that 40? It maybe interesting to find what she's making before tearing into it. It only takes something minor to make it gutless.
Father bought his good looking but doggy 40T cheap because it couldn't scuffle corn in 2nd or 3rd gear. Previous owners could put plugs,cap, rotor, points on by the dozen. They never thought about timing, advance, dist bushing,ignition wires, the PROPER plugs, valve lash, making certain the choke was 100% open, setting the throttle/govenor linkage and having the aircleaner mesh cleaned.
Might want to consider price/trade to a 420 slant dash, 430 or a 440 . Those 440's can be pretty economical to purchase.
More factory stock HP than a 40, optional live pto, optional five speed etc. And the engine ins't going to over heat when making more HP with thinner cylinder walls.
Another couple of ideas to consider if the 40 has strong sentimental value is to either slip a 420 engine into the chassis and don't tell anyone.
Or take the 40 engine an only bore it 45 over but go higher compression. There was a high altitude 40 gasser but I think they just milled the head on those? Deck the block until the pistons are flush and 125 off the head should do the trick.
There is lots more power in any old cylinder head if cleaned up. Match the ports to the manifolds, blend off casting ridges, flashing and sharp edges in the ports. Then do a proper three angle valve job and get the valves up high instead of being sunk.
Most rebuilders never give the cam and followeres a 2nd look.You can bet there is HP and smoother operation just in getting the cam trued up to factory stock specs. Even a hp or two more if you want.
That said I never seen any harm in blueprinting an engine to obtain it's potential. Going wild souping one up does have it's short and long term costs plus limitations.
Glen D Anderson
05-15-2008 12:55:41
 Re: 40U - piston oversize in reply to buickanddeere, 05-15-2008 07:39:27
Thanks for the reply,
No actual dyno test, just the "how deep can I sink the roto-tiller in the ground before it kills the engine" dyno test. Ha, but know it's not as deep as it used to be when it was "fresh".
As for the basics, the ignition system is up to par being updated to a 12V system years ago. I've installed a new coil, points, condensor, wires, Autolite plugs(always Autolite), the whole nine yards. No play in distributor bushings to speak of. Timing bang on, I even played with it to see if I could get more power with negligible results. The governor is opening the throttle W/O under load conditions. The choke issue you speak of actually caused us grief a few years back as the cable slipped in the clamp on the side of the carb. Carb had been rebuilt, no play in the throttle shaft. I'd cleaned the the air cleaner properly several years back when I used to have access to a hot tank. Put a new cylinder head on several years back when it cracked between the seats. Valve adjustments done every 2 - 3 years. Etc., etc. Suffice it to say the engine, I think is at the top of it's game considering the pistons are probably wandering around in holes that are at least ".050 to big for them. Only thing I can't speak to the condition of is the cam and followers. I could check the lift the next time I set the valves easy enough.
In the past I've seen and heard conflicting opinions of smoothing out the intake ports on engines that required power to be made in the low RPM range. I like the idea of bumping up the compression though. You can get away with taking that much off the block and head, ".125 plus?? If so what about pinging afterwards?? Running premium or VP wouldn't an option for us. I suppose a guy could rig up a water injection system, Ha!
The 40U has sentimental value to me since I remember riding on my Dads knee as a "wee lad" when he cultivated the trees around the house and other yard duties. It was the second tractor I drove, next to our 3020. So it can't go, part of the family.
What you say about the 440 is interesting as my Dad and I have always talked about having a 420/430 as we were told they had power steering and live PTO, features the 40 was certainly lacking. We didn't know there even was a 440 or that any of these tractors had 5 gears??
That would be a nice outfit for sure. What kind of $$$s would these outfits run??
Thanks again for all the info.,
Glen
Mike M
05-16-2008 05:20:21
 Re: 40U - piston oversize in reply to Glen D Anderson, 05-15-2008 12:55:41
You got to watch getting that compression too high ! We had a 440 crawler and it must of had the head milled a few times in the past ? may of had some non JD oversize pistons too ? had a terrible time of it dieseling and running hot. If I remember right ? a compression gauge would hit 150 psi on the first revolution !
Glen D Anderson
05-16-2008 07:27:53
 Re: 40U - piston oversize in reply to Mike M, 05-16-2008 05:20:21
150 psi. on the first revolution, wow! No wonder it over-heated. Did the 440 have a water pump or did it use the Thermo-syphon system like the 40?
Mike M
05-16-2008 09:30:14
 Re: 40U - piston oversize in reply to Glen D Anderson, 05-16-2008 07:27:53
The 440 had a water pump.
buickanddeere
05-16-2008 10:48:38
 Re: 40U - piston oversize in reply to Mike M, 05-16-2008 09:30:14
Cheapest high octane fuel I"ve ever found is a couple jugs of 100LL from the airport and blend a bit in with the tractor gas. Even with the block decked to bring the pistons flush. And the head milled 125thou. The compression ratio would still be less than 8 to 1. The price between 87 and 91 octane at the pumps isn"t going to cost the price of a 24 of beer per year. Final drives from a 1010 after serial number 31,001 will slow the 40"s ground speed by 15%. That would make for a considerable improvement of the roto-tiller work operation. A 420 head/manifold/carb would add a HP or two. More if the ports were cleaned up. Still like the idea of a 440 for the heavier work. The late gasser 440"s were souped above the 430 HP level. Leave the family 40 to rest in peace. A 440ID"s 2-53 can be built to run real sweet and start well. I was sinking a 9ft cultivator into the dirt with mine until the top of the muffler started to glow in 3rd gear. Backed her off though, don"t want to melt anything. It did clear the soot out of the stack and make for dozens of "fireflys". And industrial 440 missing a three point hitch is easily upgraded with a swap from a any old Dubuque from the 40 to the later 1010"s.
Glen D Anderson
05-16-2008 14:49:04
 Re: 40U - piston oversize in reply to buickanddeere, 05-16-2008 10:48:38
I suppose quite a bit could be removed from the deck and head both when the compression was only 6:1 to start with..... .....8:1 would still be quite reasonalbe.
I'll have to look at our serial #, the final drives could make quite a difference. Many times 1st gear is too slow and 2nd is only just too high.....
Was the 440 an industrial version only?? Did they all come standard with live PTO, power steering, and five speed trans.?? Many of them around anymore?? Ballpark price??
Thanks again,
Glen
Glen D Anderson
05-16-2008 15:06:54
 Re: 40U - piston oversize in reply to Glen D Anderson, 05-16-2008 14:49:04
It took a while for it register what you meant when you said the "2-53s can be made to start and run well"
They had the old two stroke Jimmys, hmmmm, they must have had a distict sound..... .
Engine parts should still be readily available for those 53 series from Detroit Diesel I would think??
Very interesting.....
Mike M
05-15-2008 05:30:47
You can sleeve them. or I have heard of a fellow who put 420 pistons in which I think are 1/4" oversize.
Glen D Anderson
05-15-2008 06:41:43
 Re: 40U - piston oversize in reply to Mike M, 05-15-2008 05:30:47
If that guy was able to use ".250 oversize pistons, ".125 should be a walk in the park.
With that much increase in bore size, the performance increase should be noticable, even with the seat of the pants dyno..... ...
Thanks,
Glen
Mike M
05-15-2008 09:55:40
 Re: 40U - piston oversize in reply to Glen D Anderson, 05-15-2008 06:41:43
I never did get any feedback as to HP or overheating ? all I know is it was done. I couldn't believe there was enough metal in there either.
