310A Hydraulics Leak
GNabors
05-14-2008 19:53:38
My 310A has had a problem with slow hydraulics for quite some time. Then, one day, it blew the seal out of the end of the steering cylinder. Got that fixed, then the very next time I tried to use it, the began leaking fluid... I first thought it was coming from the vertical filter, but I finally figured out it was coming from one or both of the "O" rings on the pressure relief valve. I replaced the "O" rings, seemed to work fine, added 2-1/2 gallons or so of fluid, put the machine to work for about an hour, as I was parking it, I stopped to check the fluid again before shutting it off (wasn"t sure if the fluid level is supposed to be checked with engine on or off, but suspected it"s supposed to be with it on,) so I began adding more fluid, and my son noticed it leaking from the pressure relief valve again, although not as bad as before. Any ideas?
Thanks
Gary
Roy Suomi
05-15-2008 20:13:51
 Re: 310A Hydraulics Leak in reply to GNabors, 05-14-2008 19:53:38
Too much pressure could be caused by the pump adjustment on the front cover of the hydraulic pump..Install a 3000 psi gauge into the pump front cover , starter side.. 2 small plugs there the upper on is the standby pressure port, the lower one is the transmission pump charge pressure[300 psi gauge]..From everything you said , I think I would check the transmission pressure on the reverser control valve to see if it's building too much pressure[ filter can leaking]..
buickanddeere
05-15-2008 12:21:53
I'm just taking a guess here but this are the suspect two high pressure relief valves on the tractor.
May have to install a pressure gauge and verify.
KEY PART NO. PART NAME QTY SERIAL NO. 310A 310B REMARKS
1 R63495 FITTING 1 X X
2 R26906 O-RING 2 X X
3 R40072 SPRING 1 X X
4 24H1283 WASHER AR X X 7/32" X 1/2" X 0.049"
5 ORIFICE 1 X X (SUB AR65882)
6 WASHER 1 X X (SUB AR65882)
7 R28776 O-RING 1 X X
8 R60332 O-RING 1 X X
9 T120368 HOUSING 1 X (SUB FOR R39323) T120368 HOUSING 1 -700276 X (SUB FOR R39323)
KEY PART NO. PART NAME QTY SERIAL NO. 310A 310B REMARKS T75263 HOUSING 1 700277- X
10 12H304 LOCK WASHER 3 X X 3/8"
11 19H2633 CAP SCREW 1 X X 3/8" X 1-1/2"
12 R39324 DOWEL PIN 1 X X (USE WITH T120368)
13 19H2458 CAP SCREW 1 X X 3/8" X 3"
14 19H3483 CAP SCREW 1 X X 3/8" X 1-1/8"
15 R26375 O-RING 1 X X
16 R39112 FITTING 1 X X
17 U12547 O-RING 1 X X (SUB FOR F3171R)
18 AT33033 FITTING 1 X X 45�
19 AR65882 CONTROL VALVE 1 X X
1 R27475 FITTING 1 X
2 R26448 O-RING 1 X
3 A4365R O-RING 1 X
4 34H254 SPRING PIN 1 X 1/8" X 1-1/2"
5 R27171 SCREW 1 X
6 AR33249 SCREW 1 X (MANUAL DESTROKE)
7 R27218 FITTING PLUG 1 X (LESS MANUAL DESTROKE)
8 R26448 O-RING 1 X (LESS MANUAL DESTROKE)
9 AR51745 DRAIN PLUG 1 X
10 R26906 O-RING 1 X
11 R27172 VALVE 1 X
12 R27564 O-RING 2 X
13 R70351 SLEEVE 1 X (SUB FOR R27476)
14 R27166 O-RING 2 X
15 R27174 PACKING 2 X
16 R27167 GUIDE 1 X
17 R27173 FILTER ELEMENT 1 X
18 R27159 SPRING 1 X
19 R27170 SHIM AR X 0.010" 24H1298 WASHER AR X 3/8" X 5/8" X 0.032"
20 U12547 O-RING 2 X (SUB FOR (2) F3171R)
21 AR26646 DRAIN PLUG 1 X
22 19H3520 CAP SCREW 4 X 1/2" X 3-1/4"
23 R26287 O-RING 2 X
24 R27216 DRAIN PLUG 2 X
25 15H560 PIPE PLUG 1 X 1/16"
26 R49072 WASHER 1 X
27 R26375 O-RING 1 X
28 T40308 O-RING 1 X
29 T57374 BACK-UP RING 1 X (USE WITH AR90378)
30 AR90378 PLUG 1 X (SUB FOR AR52495)
31 AR38714 HOUSING 1 X (MARKED R49071) (SUB FOR AR52494 OR RE13611)
32 R56755 WASHER 1 X
33 R56756 O-RING 1 X
34 R56757 O-RING 1 X
35 R107239 PACKING 8 X (SUB FOR R56754 OR (8) R69279)
36 14H1021 NUT 1 X 7/16"
37 AR52254 SET SCREW 1 X
38 R28782 O-RING 1 X
39 R28781 FITTING 1 X
40 R42260 WASHER 1 X
41 R31781 SPRING 1 X
42 R71321 GUIDE 1 X (SUB FOR R32344)
43 R70559 CONTROL VALVE 1 X (SUB RE10712, R27166 AND R41057)
44 R69262 SLEEVE 1 X (SUB RE10712, R27166 AND R41057)
.. AR56160 HYDRAULIC PUMP 1 X (SUB AR102545, P47908, R62337, F3171R, THIS APPLICATION)
buickanddeere
05-15-2008 07:50:05
Maybe too much pressure? Might be repairng the symptom instead of the cause?
GNabors
05-15-2008 11:23:43
 Re: 310A Hydraulics Leak in reply to buickanddeere, 05-15-2008 07:50:05
I"ve speculated this very thing, but what would cause it to have too much pressure?
Thanks
G
