 Henry J: I have fought the humidity wars here in the deep south. I have used separators near the compressor, farther way, lots of hose metal lines, chilled dryers, etc. Finally I found a LaMan, high capacity extractor/dryer, and it does a pretty good job. I still use a small desiccant in-line dryer right in front of the paint gun. Since I pretty much use electrolysis exclusively for paint and rust removal these days, I have not used my TIP pressure pot for a couple of years. Even then, if I got water, it was an occasion gun plug, and I could put my gloved finger over the nozzle and it cleared. Are you using a pressurized blaster? If not, the moisture problem is going to be greater. Is it possible that you are getting moisture in your sand? Maybe I misunderstand. Are you getting clogging, or just don't like the moisture that is hitting your part. Anyway, the farther you get the appliance away from the compressor to allow the air to cool before your separator, the better. The more metal the air can flow through, the better it will condense, too. I was thinking of going to a refrigerated dryer, but the LaMan unit seems to be all I need for now. When I build my shop, I'll put the compressor in the clean room, which will be air conditioned, and that will fix my problem more than likely. Frank
