Deere 4020 how to shut down?
you_1
05-14-2008 18:46:46
This recently purchased 4020 diesel needs a lot of tlc. I changed it from 24 volt to 12 volt. But have yet to fire it up. My question is how do i shut it down? It appears it must use the ignition key. There must be a solenoid to shut it down, but its not around the injector pump and i"m working under a tarp and didn"t want to take the hood of just yet until i need to. As i am changing the voltage, i want to make sure the solenoid (if there is one) is negative 12 volt ground and not positive. I don"t see anything about it in my service manual. Does anyone know the whereabouts of the device that shuts the tractor down? Thank you.
Nylon4020
05-14-2008 19:48:05
 Re: Deere 4020 how to shut down? in reply to you_1, 05-14-2008 18:46:46
On the 68 which I also own....Simply push lever all the way up to shut off diesel. There is no solenoid. The black knob on the end was used to springload a stop pin. I dont have the black knob on mine. I understand that they are used to keypin lock the throttle at pto speed and at the stop position. You pull the end knob to pull the pin out of the slot so that you can throttle above and below pto rpm. Kind of like a stop lock on some miter saws. Keeps from bumping throttle off pto setting while running. You don't kneed a work around. To start tractor, you will need to pull throttle to about the 3 oclock position. There is quite a bit of throttle arm movement available around the idle setting on my tractor. To shut it off, simply push throttle all the way till it stops in the upward position. Then remember to turn off the key.
Wilamayb
05-14-2008 19:05:22
Just as the other gentleman suggested. Your tractor's pump uses a mechanical shutoff. Just pull out the little black knob (commonly missing) on the end of the throttle lever and push the lever up past the stop. The stop knob will also have to be pulled to throttle the tractor up past rated PTO speed.
The electric fuel shutoff did not come into play until the console tractors in 1969 which would be SN's above 201,000.
jd 8420
05-14-2008 19:00:59
Pull the knob out on the end of the throttle lever and lift up.
you_1
05-14-2008 19:13:09
 Re: Deere 4020 how to shut down? in reply to jd 8420, 05-14-2008 19:00:59
Thanks guys. This is a '68 and the knob is missing. I'm trying to get everything in order to fire it up. I will have to find a work around on what that knob moved so i can shut it off when i get it going. Again, thank you.
you_1
05-14-2008 19:07:36
There is no knob on the end of the throttle. Do you know what this engages (or disengages)? The only thing connected to the injector pump is the fuel filter and the lines going to the injectors. There is one line that goes back into the tank. But i can't see what else would shut it off.
thurlow
05-15-2008 06:10:36
 Re: Deere 4020 how to shut down? in reply to you_1, 05-14-2008 19:07:36
????? ????? The throttle rod is not connected ....with ball and socket ..... .to back side of pump????? ????? It doesn't matter whether or not the knob is on end of throttle.
