2020 hydraulics
doug olds
05-14-2008 18:28:56
the loader will go up real slow and jerky. at the same time the power sterring will turn real hard and will be hard to turn both ways.
Tx Jim
05-16-2008 04:35:35
 Re: 2020 hydraulics in reply to johns48jdb, 05-14-2008 18:28:56
Doug,
Check for an internal high pressure leak. Likely places are.
rockshaft, look in filler hole with tractor running 3pt raised for spraying oil.
steering valve- feel for heat scv's-check with a gauge for leaking valves
The tubes that supply the hyd hi-lo and ind. pto are notorious for cracking therefore lowering trans pump flow to main hyd pump
buickanddeere
05-15-2008 05:36:48
 Re: 2020 hydraulics in reply to doug olds, 05-14-2008 18:28:56
How is the loader plumbed into the tractor? Has this been a sudden or gradual problem? Is the power steering ok when the loader isn"t being lifted? Does the tractor have the hydraulic high/low,rabbit/turtle shift? Is there any blown seals in the power steering or rockshaft?
doug olds
05-15-2008 20:12:18
 Re: 2020 hydraulics in reply to buickanddeere, 05-15-2008 05:36:48
The loader is plumbed into the hose coming from the filter to separate controls in the cab.It has been that way for 15 years. The last two years has been giving me problems.The power steering and the loader are troublesome at the same time. It does have the high low shift.Does not seam to have any blown seals. thanks for the help
buickanddeere
05-16-2008 10:51:47
 Re: 2020 hydraulics in reply to doug olds, 05-15-2008 20:12:18
Any difference if the lever is in rabbit or turtle? I agree it"s time to aply a presure gauge to the trans ports and find the low pressure cause. If it isn"t a line it"s one of the valve"s passing.
doug olds
05-14-2008 18:54:21
I changed the filter and cleaned the screen changed as much oil as I could took apart some of the valves cleaned them also
robersw
05-14-2008 18:45:53
The last time ours did that it was low on hydraulic fluid.
As always with hydraulic problems, the first things to check are fluid level and to make sure the filter is clean and clear.
Good Luck
Scott
