730 Transmission woes.
Grabatire
05-13-2008 22:48:37
I've got a real head scratcher on my hands.
While pulling the 730 hard in 4th it suddenly stopped moving and sounded and felt like a fine tooth slip clutch had let go. I grabbed the clutch thinking I must not have put it all the way into gear and it had jumped out. But, when I went to put it back in gear, the gear shift position indicated it was properly in gear. So, without moving the gearshift I engaged the clutch and away we went. Later in the day the same thing happened in 1st and 2nd while under a stiff load and the same slipclutch effect was heard and felt. On one occasion in 2nd it felt like it jumped out and right back in.
I'm thinking it must be something other than a sliding gear issue because the frequency of the slipclutch effect sounded and felt the same for all the gear selections involved. I would think the sound and vibrations would change depending on which gear was selected.
So far 3rd, 5th and 6th are OK.
Any ideas?
Thanks.
GNabors
05-14-2008 20:02:57
 Re: 730 Transmission woes. in reply to Grabatire, 05-13-2008 22:48:37
I have no actual help for you, just a comment... in my days as a kid, growing up on a small farm, a 730 was our main tractor, with the exact same problem. It was really frustrating... it might happen once or twice a day, or 15-20 times an hour or more! No one could figure out what was wrong with it. My Dad had the feeling that no one really wanted to work on it, so they would just tell him they didn't have a clue. I miss that old tractor, and would love to have it back! Good luck with yours.
2cylinderlp
05-14-2008 10:23:39
The camera is a Nikon Coolpix 990. Lots of them on Ebay. Has a macro function. I like it because it uses AA batteries. It eats them up pretty fast so I use rechargables. Easy to use. You can twist the body of the camera with the viewer with respect to the aperture lens for taking pictures in awkward positions. It is kind of large compared to newer cameras. The newer version of this camera is the Coolpix S4. Improved in every way. Still uses AA batteries but gets much better mileage.
machinery-man
05-14-2008 06:49:22
I"ve recently rebuilt one of those transmissions and all the shifters have lockers. Your"s probably broken, relacing the shifter"s require dissambley so I would really check for all other problems. There is a c type snap ring on the left upperside of the shaft that can release and allow that shaft to move to the side...check all aspects. If you break gears in those transmission they are very pricey, especially the external gears.
Grabatire
05-14-2008 06:33:37
2cylinderip,
Yes, I think you hit it on the head, and the picture sure helps to explain it. With all those teeth bouncing off each other, the sound and feel would be typical of those two gears not quite engaging.
Is there an adjustment that can be made to bring them into closer engagement, or do I just bite the bullet, get in there and fix it?
2cylinderlp
05-13-2008 23:52:48
third party image
I wonder if your problem has to do with the range gear? Gears 1, 2, 4, and Reverse are all over on the left side of the quadrant. When you move the gearshift lever over to that side, you are moving the range gear to engage the transmission input shaft/gear (I think). As you move the gear lever across the bottom gate, no doubt you have felt it hang up down there and you have to roll the clutch pulley a little. That is the range gear not meshing quite right to move into the input shaft/gear. The transmission input shaft/gear captures the range gear kind of like a socket wrench around a bolt head. The range gear has to be in the same position for all the gears that you mentioned. So that is the one I would be suspicious of. There is a locking mechanism built onto the shifter shafts that is supposed to hold the range gear in place. Maybe that has failed. I found a picture of a range gear. The input shaft/gear is on the right. The range gear is next to it and you can see how it engages the input shaft/gear.
Tom 43
05-14-2008 05:59:17
 Re: 730 Transmission woes. in reply to 2cylinderlp, 05-13-2008 23:52:48
What kind of camera are you using to take such great close up pictures? Are you using a special lense or are you actually putting the camera in the transmission?
