4020 rear wheel bearings
Scott Taylor
05-13-2008 21:22:23
I have a 1967 4020 powershift. It has a intermittent grinding noise in the right final drive. Some advise brake noise and others say wheel bearings. Looking for advice on removing final drive to look into problem. Thanks any advice is welcome.
Bob
05-14-2008 09:36:13
 Re: 4020 rear wheel bearings in reply to Scott Taylor, 05-13-2008 21:22:23
Try jacking that side up a bit, then dropping it (lowering the hydraulic jack) while watching for movement of the axle relative to the axle housing.
If you HAVE to take it apart, support things SECURELY, then remove the circle of bolts holding the final drive to the main case, then simply move the final drive away from the main case.
OH YEAH, before doing all that be SURE the wheel center isn't loose on the axle OR the rim isn't loose on the casting, moving around a bit, and making strange noises!
