JD3130 selective control valves
Kanuck
05-13-2008 18:50:55
Hi there, We seem to be having trouble with one of our selective control valves (poppet type) that controls one of our rear hydraulic ports on our 3130 tractor. We use this one primarily to raise and lower our round baler gate. It seems to have alot more resistance and more force is needed to push and pull lever. Otherwise it still operates baler gate okay. Anyone have something similar or any luck in rebuilding one of these valves? I should also mention that we get the same result regardless of having something hooked up to the rear port or not. Thanks for any help you may be able to give.
msb
05-14-2008 07:26:38
 Re: JD3130 selective control valves in reply to Kanuck, 05-13-2008 18:50:55
Sounds like a detent problem. I would have someone look at it soon. You could destroy the box if it is let go too long.
