3020 Fuel Gauge Troubles
glsinNY
05-13-2008 17:10:31
Replaced the fuel gauge and sending unit on my '64 3020 and still the same thing, stuck on "F" when the tractor is running. It's a 12 volt system with an alternator..... .it puts out 2.3 volts at the unit on the tank, and almost 12V at the gauge(the old unit read the same. Could it be a bad wire?? I switched the terminals at the guage and still have the same issue.....any ideas? Thanks, Gordon
Larry in WNY
05-14-2008 09:19:54
 Re: 3020 Fuel Gauge Troubles in reply to glsinNY, 05-13-2008 17:10:31
Gordon,
I did the same thing with my 3020. You need a good ground for the gauge. Is there a 3rd terminal on the gauge for a ground?
Larry
glsinNY
05-14-2008 14:13:03
 Re: 3020 Fuel Gauge Troubles in reply to Larry in WNY, 05-14-2008 09:19:54
Larry,
Thanks for the heads up. There is no third terminal on the new gauge. I cleaned any and all paint and rust from the back side of the dash as well as the places where the dash attaches to the tractor to try to get a good ground. I think it is supposed to ground to the dash? Is there any other way to ensure a good ground?
Thanks again!
Larry in WNY
05-14-2008 19:22:14
 Re: 3020 Fuel Gauge Troubles in reply to glsinNY, 05-14-2008 14:13:03
It's been a few years since I did mine, but I think I ran a wire directly to a bolt. I can check this weekend. My 3020 is at another location. Last year the gauge came loose in the dash and one terminal was touching metal which caused it to read incorrectly. After it was tightened and adjusted it worked OK. I'll let you know what I find.
Larry
glsinNY
05-15-2008 03:28:02
 Re: 3020 Fuel Gauge Troubles in reply to Larry in WNY, 05-14-2008 19:22:14
Thanks!!!
powertech84
05-13-2008 17:33:02
sounds like a bad connection or broken wire. check continuity from the gauge to the sender.
glsinNY
05-14-2008 03:58:25
 Re: 3020 Fuel Gauge Troubles in reply to powertech84, 05-13-2008 17:33:02
Powertech,
Should there be 12 volts at the tank?
