620, 630 Exhaust Manifolds - Why The Short Lifespan
GlenT
05-13-2008 12:11:20
Does anyone know why the manifolds crack on the later Waterloo tractors and does the position of the Hot/Cold Valve make a difference in longevity?
I have been running a new one for 16 years on a 620 and have been religiously changing the Hot/Cold Valve setting in the Fall and Spring and so far, so good, but I have seen more valves froze up than not at tractor shows. Also, does anti-seize help keep them loose? Any ideas on keeping them working?
Thanks
RobMD
05-13-2008 12:28:16
 Re: 620, 630 Exhaust Manifolds - Why The Short Lifespan in reply to GlenT, 05-13-2008 12:11:20
Constant expansion/contraction by hot and cold running is hard on a manifold mulitplied by 50 years.
Anti-seize will burn off eventually. Keeping them free is kind of hard, but being religious with them helps a lot. What happens is that the farmer just stops fooling with it and then when he goes back to set it for cold weather, it's stuck. Oh well, shrugs the farmer.
F-I-T
05-13-2008 14:25:57
 Re: 620, 630 Exhaust Manifolds - Why The Short Lifespan in reply to RobMD, 05-13-2008 12:28:16
I think Nev-R-Ceez is a better bet than anything else. When Nev-R-Ceez "burns off", you are left with graphite power, which is a good seizing deterent. In the jet engine world, we used to coat the roots of compressor and turbine blades with an "anti-galling" compound, which was nothing more than a simple varnish with a lot of graphite powder. The varnish would burn off and the graphite would remain so that the blade would have some lubrication when it came time to remove it. If you galled the disk up driving out the blade it got expensive real fast.
Since a manifold gets hot, but not always red-hot, you could try some Nev-R-Ceez on a piece of steel, or between two pieces of steel and heat them up, let'em cool and see what you have for lubricity. One way to find out, but it's what I use.
Frank
RobMD
05-13-2008 18:09:24
 Re: 620, 630 Exhaust Manifolds - Why The Short Lifespan in reply to F-I-T, 05-13-2008 14:25:57
Man.. I forgot about the graphite residue.. that's the grey color in the can. But doesn't graphite just crust away if there is no medium to help it "stick" to parts?
ncpapaul
05-15-2008 14:08:10
 Re: 620, 630 Exhaust Manifolds - Why The Short Lifespan in reply to RobMD, 05-13-2008 18:09:24
Where can you buy that Nev-R-Ceez?
F-I-T
05-13-2008 19:19:23
Yeah, it's not the grease vehicle that makes Nev-R-Ceez so slick, it's the grapgite powder. I think it would swedge into the cast iron pores and stick. I know when we used graphite lube on our forging dies, it was a heckuva job getting the stuff off of the 17-4 ph and a-427 steel. And, it's impervious to heat.
It should provide more protection and lube than clean cast iron for sure.
