Fixing Dents in Sheet Metal
DEEREMANJRC
05-13-2008 10:04:33
I'm going to be starting to try to fix some dents in the grill of my JD MT, and I'm wondering how is the best way to fix them so they are fairly nice. I don't have really any equiptment except 2 hammers and some misc. tools. It doesn't have to be perfect right now, I just want to get it looking a little better before I paint it. I'm painting it at the moment to keep it from rusting with the hope that sometime in the future to do a complete restore. Any good suggestions would be much appreciated.
Thanks,
Jake
msb
05-14-2008 07:30:40
 Re: Fixing Dents in Sheet Metal in reply to DEEREMANJRC, 05-13-2008 10:04:33
You can use a torch and heat the area in a circular motion. Then slap a cold water soaked rag on it. That shrinks the dent.May have to do it several times.
Nathan Kapp
05-14-2008 05:06:57
Why not try a body shop who does paintless dent repair on cars? A buddy of mine had this done to a dent on his truck door and you'd never know there was ever a dent there. Just a thought.
Nate
Mike M
05-14-2008 12:03:02
 Re: Fixing Dents in Sheet Metal in reply to Nathan Kapp, 05-14-2008 05:06:57
Tractor metal is way thicker than car metal so it is doubtful they can push them out with their tools.
A body hammer, dollies, and LOTS of patience ! is what it takes. Very few body people today can or will work on tractor metal.
garytomaszewski
05-13-2008 11:29:17
Bodymen will cringe, but if you have no shaping tools, you can use many washers bolted together; right diameter to match curve,lay them on your leg NOT something hard ,lay the part over and LIGHTLY knock out the dent, this usually doesn't strech the metal. Same with flat pieces 2x4 on leg and on convex side of dent, tap metal around dent in circles getting smaller until dent is almost smooth, then work on convex. Hope this makes some sense, way easier to show than tell.
RobMD
05-13-2008 11:11:14
You can do it with sheetmetal forming hammers and dies, but it's meticulous. I just did a grille on a 730, took me 5 hours to repair the front. Even when you get all the dents out, there will be hundreds of "mini-dents" where the hammer has been hitting. Of course, they're not terribly noticeable, but when you slap on a fresh coat of green, the dents will show up in the reflection. This is when you must use fiberglass resin and sanding. NOT fun.
Rich Va
05-13-2008 11:06:10
I took mine to a body shop. If you're going to make some improvement now and then later on do some more improvement you might as well get it over with the first time.
