4010 leak
MN Bob
05-13-2008 05:30:40
Advice needed here. I have the op manual but not the parts or service. I just put the batteries back in, serviced and test run. I have what I believe is hydralic oil leaking down below the oil cooler. Would this tie into the power steering? Prior to this spring I had occasionally noticed a dark spot in the dust after working but never a leak like this. Could it be a seal that will soften and close up? Appreciate advice. Bob
61-4010
05-13-2008 10:49:33
 Re: 4010 leak in reply to MN Bob, 05-13-2008 05:30:40
MN Bob - - Greeting from NC. The leak you are describing can be from several area up there. First, there is a rubber hose/line that connects the oil cooler to the hydraulic pump that may be leaking. And of course there are the power steering lines as well.
I would do the following: First, take off the side screens and start up the tractor. With someone turning the steering wheel, check to see if you have any noticeable leaks. By turning the wheels side to side, it will apply pressure to the lines. If no leak, I"d go to step 2 (below).
Step 2 would be with the motor off! Once shut down, you can reach up and underneath above the pump to see if the oil is coming from the oil cooler area. If so, you may have a leak in the oil cooler itself or one of the lines feeding the oil cooler. The pressure in the oil cooler is very low...nothing like that which would come out of the pump.
Good luck and keep us posted.
MN Bob
05-15-2008 19:20:22
 Re: 4010 leak in reply to 61-4010, 05-13-2008 10:49:33
Thanks for the response. I will be at the farm tomorrow, I will try that. Hope its the hose. Bob
