4020 Hydraulic pump chatter
RLFox
05-12-2008 20:03:00
My "67 4020 diesel seems to have a chatter from the hyd pump when its not under load. I changed the filters and oil about a year ago, but used non JD oil, wonder if that is part of the issue. Perhaps related, the steering gets a bit jerky when its been run for a few hours on a hot summer day. Wonder if that oil is breaking down?
jdemaris
05-13-2008 05:29:06
 Re: 4020 Hydraulic pump chatter in reply to RLFox, 05-12-2008 20:03:00
Internally, the stroke-control valve is the #1 wear item in that pump. It will chatter like crazy when there is no load on the pump - and get quiet when you use it. When it gets real bad, it will make the tractor start hard and burn up starter motors.
It can be replaced with the pump on the tractor. I installed many over the years on tractor "road calls."
low budget
05-12-2008 21:02:24
Chatter could be a loose pump drive, usually just needs new bushings. About a $10 fix.
Tony S.
05-12-2008 20:12:51
Our 4020 chattered for 20 years. I quit worrying about it. The jerky steering (and brakes?) can be caused by a clogged screen in the sump. It pulls out of the hole where the drain plug is. The screen clogs because the brakes are internal, and anything that wears off collects in the sump.
