60 speed hunting
matthies
05-12-2008 19:20:37
Was wondering what I'm not doing or seeing. I had the head and cylinder block off of this tractor and now the engine speed hunts worse at idle than at wot. The tractor wasn't running before I started working on it antifreeze was in the cylinders. And my friend never said anything about this. Went through the carb before and again after I had it running and also tried a different carb and adjusting the timing. Pulled the governor shaft and the weights are free and sliding on the shaft and tonite tried adjusting the linkage two turns both ways and still nothing. I did read about the 1/2-1 hole off of the throttle shaft and I'm there. thanks chris
Hood Patch
05-13-2008 12:45:15
 Re: 60 speed hunting in reply to matthies, 05-12-2008 19:20:37
Did you have the block and head milled any while it was out? It doesn't take much milling on either or both to get the carb. linkages messed up. The linkage will now need to be adjusted(should need to be shortened alittle).
Matt @ miller
05-13-2008 08:12:45
How�s your Governor spring, a weak spring will do this. Also when you run the tractor have you pulled the choke out to see if it will run right, even if you have rebuild the carb there is passages the are very hard to clean with out taken the little balls out.
Mike M
05-13-2008 04:27:12
If you happened to put in throttle shaft bushings maybe they are too tight ?
F-I-T
05-13-2008 01:06:42
If you disconnect the speed control rod from the carburetor and operate the carb butterfly by hand, does it still hunt? I like to do that to prove to myself if the carburetor indeed is the culprit or is it getting bad input signals. If it runs well without governor input, it might still have a governor problem.
When it hunts, is it just up and down, or does it miss any time during the event.
Curious to know what you find.
Frank
Tom 43
05-12-2008 20:05:25
Did you try a known good carb that allowed another tractor to idle smoothly? Check for vacuum leaks where the carb bolts to the manifold and where the manifold bolts to the head by spraying carburetor cleaner on the seams.
buickanddeere
05-12-2008 19:25:55
Both idle circuits working in the carb? Timing both static and advance?
Preload on the governor spring can be twitchy with worn parts. The operator's manual has a very good step by step procedure for setting up the carb and linkages.
I tried it once or twice without the manual thinking "how difficult could it be"? I eventually went to the cupboard and got the manual out.
