4430 hydraulic problem
Sdalp
05-12-2008 18:54:59
Unloading 2000# bags of beans the loader will
lift the load off the trailer just fine, but when
I lower the load to the ground and back away form the pallet I have no hydraulic pressure for a short time. After waiting the tractor will shake a little
then I can lift again. Any suggestions?
Ducknose Bob
05-13-2008 07:26:24
 Re: 4430 hydraulic problem in reply to Sdalp, 05-12-2008 18:54:59
Pull the hex shaft out of the a$$ end of the tractor, you will see the wear on the shaft where it drives the charge pump.
buickanddeere
05-13-2008 07:11:10
It does sound like either high flow demands in the transmission or low pump capacity. Hence the test lifts when the transmission isn't in gear.
Some of those had a thermostat bypass system for the oil cooler/front reservoir tank. Maybe something stuck there?
A flow test to verify adequate supply to the front pump should be performed.
The loader and tractor hydraulics will operate much better/faster/cooler if properly plumbed through a "power beyond" circuit. That is a direct high pressure line to the loader valves straight from the high pressure hydraulic line. Even more important is the return line not being routed back through the scv but direct to the trans oil filter housing.
The scv's are designed for low flow occasional use loaded such as cultivator lift cylinders etc. Certainly not for loader, log splitter or air seeder hydraulic drives. Something has to be repaired anyways. May as well install the vital filter cover when at it.
KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 Y1912 PART NOT CODED 1 8-1/2"
2 F3171R O-RING 1
3 R394R O-RING 1
4 R54750 SCREW 1
5 T31170 COVER 1
6 R34733 WASHER 2
7 R66068 PIPE 1
rexhellwig
05-13-2008 04:11:28
If a new filter {two filters, if it's a power shift} and a clean screen does not fix it, you are going to need someone with some training on this system. It's going to need a test called an "element leak check".
Chattering and slow operation happen when there is little or no oil going forward to feed the main hydraulic pump. There isn't going to be any oil going forward until everything in the transmission gets what it wants first. The pump only gets what oil is left over. So any leaks inside the transmission will need to be fixed.
buickanddeere
05-12-2008 19:39:57
The 30 and later series waterloos were supposed to have a dedicated 100% duty cycle trans oil pump drive???
Just out of curiosity. Try lifting the load with the trans in park, then shift into gear, drive, put in park, lower load, raise loader, put in gear and drive. When was the last filter and screen service?
How is the loader hydraulics plumbed to the tractor hydraulics?
Has this problem suddenly of gradually appeared?
Sdalp
05-14-2008 04:22:46
 Re: 4430 hydraulic problem in reply to buickanddeere, 05-12-2008 19:39:57
Didn't seem to make a difference when I in park or moving wheni lift & lower the load. I had one suggestion that there is a screw that can be adjusted for single acting cylinders to dump oil back to the reservoir. I don't know
the location of that screw or if that would help.
Sdalp
05-13-2008 04:29:20
Transmission oil & filter is change every year,
last changed over winter. The screen was checked last year at oil change. The loader is plumbed into the tractor scv. I just started having this problem with unloading the bean bags. Didn"t have problems with using for snow in the winter. I have had a shaking
like this upon startup for a long time where if you
wait a few seconds it will work. It seems to have good pressure after it stops shaking.
buickanddeere
05-14-2008 05:53:42
 Re: 4430 hydraulic problem in reply to Sdalp, 05-13-2008 04:29:20
Sounds like the anti-drainbade check valve is sticking open as well. All in all, it"s a 35 year old machine. Wear,time and a spec of dirt is all it takes.
Sdalp
05-14-2008 08:10:17
 Re: 4430 hydraulic problem in reply to buickanddeere, 05-14-2008 05:53:42
Where is this check valve located?
buickanddeere
05-14-2008 11:30:37
 Re: 4430 hydraulic problem in reply to Sdalp, 05-14-2008 08:10:17
It could be just about anything. We would be doing you a dis-service by guessing and putting you on a wild goose chase. Only way to know is to find either a leakor low flow problem and repair. Deere did release a high volume transmission pump for those tractors. If you connect the loader up direct and return oil to the filter. That supplies oil to the front pump without having to pass through the trans pump bottle neck. The ported filter cover is well known. I don't know who would connect a loader or any other dedicated high flow load up without using one.
Sdalp
05-15-2008 04:08:54
 Re: 4430 hydraulic problem in reply to buickanddeere, 05-14-2008 11:30:37
Thanks for all the help. will look into
plumbing the loader into a direct line.
Roger in Iowa
05-13-2008 09:21:43
Try plumbing into the left hand side SCV. Thought it was supposed to be used for hydraulic motors and returns to pump circuit.
Roger in Iowa
