51 G Wiring
MDM
05-12-2008 17:56:40
I have found a 12 volt generator with regulator and have had it rebuilt, does anyone have a diagram showing where all the terminals should be wired to? Should this be positive or negitive ground?
James Howell
05-13-2008 11:00:52
 Re: 51 G Wiring in reply to MDM, 05-12-2008 17:56:40
Hope this helps.
PBrowning
05-12-2008 18:35:37
Check in over at the JD-H Restoration Site (below). Scan across to ARTICLES 2. From the drop-downs, select WIRING DIAGRAMS 3, and then follow the string down to JD-G. You can print the two-page document -- should be clear enough. (PatB)
MDM
05-12-2008 20:02:59
 Re: 51 G Wiring in reply to PBrowning, 05-12-2008 18:35:37
THANKS!!!!! !!
