1941 H Governor...AGAIN
Russell6HP
05-12-2008 12:40:36
I got my governor aligned and installed...only to find that the magneto drive flange isn"t engaging the magneto lugs. I am greatly puzzeled by this, because when I removed the governor shaft and did my work, I did not remove the flange from the shaft. Any ideas? Everything else lines up correctly, and the mag trips if you spin it by hand (so I know IT'S good).
Jerry Pevehouse
05-13-2008 08:48:29
 Re: 1941 H Governor...AGAIN in reply to Russell6HP, 05-12-2008 12:40:36
Was this mag on the tractor before? Just wondering, and it seems elementery, but are you sure it has the correct drive on it (short or long lug)? Sometimes it's the simple stuff that baffles us till we think about it. Good luck, Jerry
Russell6HP
05-13-2008 13:44:45
 Re: 1941 H Governor...AGAIN in reply to Jerry Pevehouse, 05-13-2008 08:48:29
That is correct, it is the same mag as before (Wico Type X). Everything was running fine until I tore into it (err...with the exception of the governor itself, which is what led to it's removal).
Pat, when you say left bearing, are you meaning the one pressed into the cover that the shaft terminates into (flywheel side)?
PBrowning
05-13-2008 14:54:15
 Re: 1941 H Governor...AGAIN in reply to Russell6HP, 05-13-2008 13:44:45
Russ -- That bearing is in three parts. The race pressed into the L.H. Bearing housing, the race pressed onto the shaft, and the caged roller bearing assembly in between. During assembly, the roller cage can slip down out of position, thus allowing the spring-loaded governor shaft to move toward the flywheel side of the tractor -- it don't take much movement to lose engagement between magneto and the driving flange on the governor shaft. You may call me at (830) 627-0430 if confused. (PatB)
Russell6HP
05-14-2008 06:25:35
 Re: 1941 H Governor...AGAIN in reply to PBrowning, 05-13-2008 14:54:15
Pat,
Now I'm tracking you. Will check for that tonight. Thanks again!
PBrowning
05-13-2008 09:28:53
Good point -- All "H" tractors used the short lug drive cup.
All "A" tractors, 1940-up, all "B" tractors, 1941-up, and all styled "G" tractors also used this same magneto -- that is, WICO with the short lug drive cup.
And if my memory serves well, this same magneto is used on AR & AO tracotrs, 1941-up. (PatB)
PBrowning
05-12-2008 14:19:58
Russell -- Could it be that the L.H. governor bearing slipped out of position when you put it back together -- thus allowing the shaft assembly to shift to the left side some?
One quickie test is to check fan shaft backlash. If it is excessive, the shift is out of position to the left.
This is a good arguement for always integrating the fan shaft & governor (on the bench) BEFORE installation onto the tractor. You would catch something like this -- assuming this is it! (PatB)
JDNPC
05-12-2008 12:48:24
check and see what lug you have on your mag. also check to see if you have the correct mag. you may want to vist JD H PUBS website for some insight and technical assistance
