J.D. 4020
pilot199
05-12-2008 09:18:27
Bought a '63 model 4020 last year & just had it converted to 12VDC using the standard dual batteries in parallel. Now having trouble restarting the tractor after the initial conversion. Both batteries were load tested & show good & the new alternator is putting out 15VDC.
A few things I question:
1. The original ground strap is half the size of the other battery cables. Is this causing a flow problem?
2. When converting the starter to 12VDC is it geared fast enough to spin the engine sufficiently at the lower voltage?
3. How accurate are load tests on batteries at common auto parts stores?
Any help is appreciated. Thanks,
Gary Baton Rouge
a russell
05-13-2008 19:19:32
 Re: J.D. 4020 in reply to pilot199, 05-12-2008 09:18:27
Did you use a small ford type solenoid between starter solenoid an switch? If not then your switch can't carry enough juice to the starter. A Russell
Tony S.
05-12-2008 20:17:37
There's nothing more worthless than those long skinny tractor batteries. I built some brackets for 12V car batteries. Half the price, last twice as long. Never had any more trouble starting the 4020.
Mike M
05-12-2008 12:30:41
I had the exact same thing happen to me with a JD 500 I converted.
Bob
05-12-2008 09:36:15
You need BIG battery cables for 12-Volt, as well as some decent batteries... I would use 800 to 1000 CCA (each) batteries.
Was the starter "converted", or did you exchange it for a 12-Volt unit? Unless it is a late-model starter, whether 24-Volt or 12-Volt, it is not "geared" at all, but is a direct drive unit.
Guys have reported on here about having good luck with using late-model gear reduction starters for these 4020 12-Volt conversions, but I'm not sure of the exact original application or part number.
pilot199
05-12-2008 10:54:28
 Re: J.D. 4020 in reply to Bob, 05-12-2008 09:36:15
Thanks Bob,
The starter was converted at a local automotive shop & now that you mention it I believe my starter is a direct drive. On my next trip to the farm I plan to change that ground strap to a larger cable.
Thanks,
Gary
Gerald J.
05-12-2008 11:18:44
 Re: J.D. 4020 in reply to pilot199, 05-12-2008 10:54:28
That conversion is probably your problem. Most every comment I've seen says the Nippon-Denso starter from later tractors is worth the money when starting the 4020 diesel.
Gerald J.
pilot199
05-12-2008 13:15:26
 Re: J.D. 4020 in reply to Gerald J., 05-12-2008 11:18:44
Gerald thank you,
That Nippon-Denso starter is that an after market brand or does JD use these on their tractors from the factory?
Gary
Gerald J.
05-12-2008 13:27:12
 Re: J.D. 4020 in reply to pilot199, 05-12-2008 13:15:26
Deere used it on later tractors.
Gerald J.
