4020 injection pump(steel VS copper washers)
Glen D Anderson
05-12-2008 08:00:17
I had the lines for the injectors removed from my injection pump and after re-installing them I could not get the banjo fittings on the pump to re-seal. 2 or 3 fittings would continuosly sweat no matter what I did. So I installed new banjo bolts and washers(steel) with basically the same results, the fittings were still sweating.
The banjo fittings on the injection lines had some areas that were somewhat galled from the fittings being installed and removed. I used a fine file to remove the high spots which seemed to help but I couldn't get rid of the sweating.
Finally I remembered I had some copper washers from years ago, I installed them and found that they had cured the leaks/sweating.
I've had the lines off of three of our 20 series tractors multiple times and never had leakage issues like this before.
What could I be missing??
Thanks in advance,
Glen
msb
05-12-2008 19:27:36
 Re: 4020 injection pump(steel VS copper washers) in reply to Glen D Anderson, 05-12-2008 08:00:17
10 Series used copper initallly, but I have always liked the steel washers better than nhe copper. If you look closely at the steel washers , you will see they are convex from being stamped out. Place the cupped side against the banjo fitting, but before you do, dip the parts in a quick evaporating type paint thinner and swish them around a bit.I use Deere paint thinner. This washes away any trace of oil or grime that will attract dirt in the air. Then blow all parts dry and assemble.Clean and dry parts don't attract any dirt or dust. There is usually enough dust and dirt in the air that will attract to any oil on any of unwashed the parts.If you don't believe me, simply dip a magnifying glass or any small piece of glass in diesel fuel and hold it up in the air.Then dip the glass in paint thinner and observe it. You will see tiny flecks of dust in the fuel film right away on the glass.You won't see any flecks on the washed glass. Next, be sure the lines are not in any stress or the vibration from the engine will wiggle the piano screws loose. I have been using this procedure for over 40 years with no problems OR leaks.
jdemaris
05-12-2008 12:18:18
I can't tell from here if you're tightening properly or not. But . . . we had many over the years with that sort of problem. Crack the leakers loose once with the engine running and then retighten. That can clear small particles of debris if stuck in there. Sometimes the line-ends - and/or pump surfaces get scratches and the only fix that will work is copper washers. They don't hurt a thing - I've put them on many Deere, Cases, Fords, and ACs over the past 40 years with zero problems.
Bob
05-12-2008 09:07:24
You didn't tighten them TIGHT enough. They have to be just short of breaking off before they will seal.
Glen D Anderson
05-12-2008 15:21:23
 Re: 4020 injection pump(steel VS copper washers) in reply to Bob, 05-12-2008 09:07:24
Thanks for the replies,
I'd tried loosening and tightening the fittings while it was running as that trick has worked for me in the past, but no luck on these ones.
How tight are we talking here? Obviously I didn't use a torque wrench but I'd have to guess I was getting 35 ft/lbs plus. Is there any danger of distorting the head on the injection pump? Also, should I be lubing the threads and washers with something other than the fuel that is present?
Thanks,
Glen
Mike M
05-12-2008 11:04:14
LOL !!! I know what you mean I still can't believe I haven't twisted off a bunch of those. Do you think his copper washers will be fine ? I wonder why they didn't use them originally ?
rexhellwig
05-12-2008 12:52:30
 Re: 4020 injection pump(steel VS copper washers) in reply to Mike M, 05-12-2008 11:04:14
"..Do you think his copper washers will be fine ? I wonder why they didn't use them originally ?.."
They will work OK for a while. Since the copper is softer, it more easily conforms to the imperfections in the line. But the vibration will cause the copper to "settle", the screw to loose tension, and eventually it will start leaking again.
With the limited use these tractors see these days, it might not leak for years.
