36 B NEED HELP WITH IDENTIFICATION
flyingjd
05-12-2008 06:48:48
Went and bought a '36B this weekend, at least serial number tag says '36. Problem is it is a 6 speed and I know they did not come in'36. I have heard there was an overdrive that could be installed. How can you tell if there has been one installed or this is a home made tractor? It does have 10 spline axles and appears to have most things unstyled tractors came with. Would appreciate any help I can get.
Anderson
05-12-2008 15:26:11
 Re: 36 B NEED HELP WITH IDENTIFICATION in reply to flyingjd, 05-12-2008 06:48:48
A picture would tell alot. And im sure there are plenty of guys on here that could tell you right away what exactly you have.
deere-tom
05-12-2008 09:55:19
The only thing is that most of the parts fit on the B. Enjoy the fun! Tom.
deere-tom
05-12-2008 09:26:37
I have a B with parts from all years on it. I have more than a little fun with it when I get (we had one just like it) have fun with the B. Tom
flyingjd
05-12-2008 09:35:51
 Re: 36 B NEED HELP WITH IDENTIFICATION in reply to deere-tom, 05-12-2008 09:26:37
Maybe Johnny Cash built this one piece at a time!
Mike M
05-12-2008 08:04:05
First off how are you counting the speeds ? 4 forward and 2 in reverse if the hi range lock out was removed could account for 6 ? THE Belhen add on overdrive would be mounted on the LH outside of the trans. case. behind the flywheel and they usually have their name on the cover and a seperate lever.
flyingjd
05-12-2008 08:11:17
 Re: 36 B NEED HELP WITH IDENTIFICATION in reply to Mike M, 05-12-2008 08:04:05
It has been completely repainted so no labels are visible. There is an added section behind flywheel but I don't see an additional lever.
deere-tom
05-12-2008 07:16:31
Your B most likely has motor,trans,and main case from 41-46 with unstyled front and rear end. This is quite common.
flyingjd
05-12-2008 08:04:42
 Re: 36 B NEED HELP WITH IDENTIFICATION in reply to deere-tom, 05-12-2008 07:16:31
Thanks you are most probably right. It is a good runner and looks great so I am happy with whatever it is.
