51 jd a
johndeereman
05-12-2008 05:08:27
im working on a 51 A does anyone know the numbers for the governer bearing on the left side? also would a factory stock A be competetive pulling with 14.9 firestone field and roads? i just pulled sat. with those tires on my dc case and run out of power in the 5500 lb class thinking about switching tires and trying the A next time whats your opinion?also im trying to time the gov. the book says line the lh exhaust mark on cover and turn gov. so that the dist. drive is horizontal im just not sure wich dimple is the lh exhaust there is a dimple right before the words and there is two dimples right above the words which one do i want? thanks for your help
Mike M
05-12-2008 06:38:23
 Re: 51 jd a in reply to johndeereman, 05-12-2008 05:08:27
jd 7654 IS THE BEARINGS for the gov. and fanshafts.
John T
05-12-2008 06:16:14
Its been tooooo oo long since I pulled any A's but seems like in low gear she would slip those 14.9 tires so a 15.5 might be better if you had to use low gear due to rules.
The LHI timing mark at 3 o clock even with the flat mark on tractors side (thats used for timing) is when the left piston is at dead TDC sooooo oo remove the left plug n use a wire etc indicator to determine just when the piston is at TDC and thats when the female slot in the governor shafts end ought to be flat horizontal fore n aft. My guess is the one flywheel punch mark is at TDC while the two marks located above/before (if thats where they indeed are) are is for something like say 20 or 30 degrees BEFORE TDC. If you measure the flywheels outer circumference and divide by 360 you would get degrees per unit inch and perhaps?? those above/before marks work out to where a timing light could be used to measure dynamic run time advance..... ... Anywho, get the left pistion at dead TDC and set the governor so its female drive slot is flat horizontal fore n aft is the bottom line assuming????? the flywheel to crank and cam to crank are all in time.
John T
