755
awagnblas
05-11-2008 20:45:30
Any problems common to the 755? I"m going to look at one tomorrow with about 1000 hrs. thanks
Roger in Iowa
05-12-2008 09:52:07
 Re: 755 in reply to awagnblas, 05-11-2008 20:45:30
755's are weak sisters. No power unless you have them wound up to full high idle rpm!
Go for an 855 or 955.
Roger in Iowa
Mike M
05-12-2008 04:45:31
Look closely around the head to block seam for evidence of an antifreeze trail from a leaky head gasket. I have heard of a few that had head gaskets replaced.
leon
05-12-2008 04:01:07
Usually good tough machines, especially if serviced regularly. Replacement radiator grills are about $400! If you plan on using a snow blower or loader on it, I'd highly recommend that it be a front wheel assist model. You might even want to hold out for a longer wheelbase, heavier, more powerful model 855 or 955 - depending on what you plan to do. 1000 hrs sure is a low hour one.
