Cap Screw Head--JD B
elcajonfarms
05-11-2008 19:19:34
I'm wondering if anyone has an idea where to find the driver or socket that fits the unusual cap screws used in a late styled JD B, for example, two of the screws holding the flywheel cover in place on my B have an oblong hole with a slight wasp waist that must require some sort of proprietary driver in lieu of an Allen head or similar driver. Some of the other sheet metal screws on the tractor have the same head. I suppose I could just use the trusty old Vise-Grip to twist them out and replace with a more common screw, but would like to preserve if possible. Anyone know where to find this tool?
Pete in MD
05-12-2008 13:00:57
 Re: Cap Screw Head--JD B in reply to elcajonfarms, 05-11-2008 19:19:34
Try your NAPA store. A 5/16" clutch head driver that I got at NAPA has M-138 on it. It's heavy duty with a big thick handle that you can really apply torque with.
elcajonfarms
05-13-2008 21:17:55
 Re: Cap Screw Head--JD B in reply to Pete in MD, 05-12-2008 13:00:57
Believe it or not, even my local suburban Napa Auto store in the San Francisco Bay Area had this tool in stock-- although they had no idea what I was talking about when I asked, could not find the tool even when I gave them the Napa part number, and barely acknowledged the fact that I was able to spy the tool despite the part number being covered up by a roll of tape that they had hung on the same peg, when I saw the M-137 tool hanging right next to it behind the counter!! This did the trick, though, and I appreciate your suggestion.
Mike M
05-12-2008 04:47:43
You can also take another screwdriver and regrind it to fit in that slot. I got by that way for a few years until I bought the proper screwdriver.
jdhbag
05-12-2008 04:16:02
Those clutch head bolts can be gotten from Correct Connection 1-814-926-277. In fact Joe has just about all the special bolts for the John Deere tractors. Snap On has a clutch head bit # SDM246G which is the 1/4 inch one for around $5.00.
Bob
05-11-2008 19:34:26
You need a "clutch head screwdriver".
Even some cheap driver bit sets have a couple of clutch head drivers in them, and, of course, there's the $$$$ tool salesmen!
Third Party Image
elcajonfarms
05-11-2008 19:50:05
 Re: Cap Screw Head--JD B in reply to Bob, 05-11-2008 19:34:26
Thanks--this is why I appreciate YT!!
hardscrabble
05-11-2008 19:30:38
Those are called "clutch-head" screws. Screwdrivers or bits might be hard to find, but I beleive they are still available. (I have a '49 A with the same type of fasteners.)
elcajonfarms
05-11-2008 19:51:08
 Re: Cap Screw Head--JD B in reply to hardscrabble, 05-11-2008 19:30:38
Thanks for the information--will look for this next time I'm in a tool department!
