3PT IMPLEMENT WANTED
RICKY C
05-11-2008 17:40:42
third party image
what type of implement would hook up behind a 1950 jd b 801 3pt hitch and not stick out 12ft so i can pull it on a trailer with my other tractors. trailer is 31" tall with 3 ramps. has to be john deere and in that time frame. thanks
Wilamayb
05-11-2008 18:19:07
 Re: 3PT IMPLEMENT WANTED in reply to RICKY C, 05-11-2008 17:40:42
Be aware that just about any implement on a B will require that ballast be added to the front of the tractor. The 50 was much heavier in the fron end than a B, and just about all implements suited for 800-801 hitch list front ballast requirements when used with the 50, and you are even lighter than that. A 2-12 plow may be hard to find, but may suit you better. 2-14 will be all and more than you need being mounted without several pounds of front weight.
RobMD
05-11-2008 17:46:08
2 bottom 14 or 16 inch plow. 246/247 corn planter. Number 9 sickle bar mower.
ricky c
05-11-2008 18:23:56
 Re: 3PT IMPLEMENT WANTED in reply to RobMD, 05-11-2008 17:46:08
thanks to both of yall. the weight deal is very helpfull due to loading. not really wanting to work it but to show it. thanks again
