Note what Paul is telling you. The objective here is to move the cylinder block and BOTH pistons FORWARD. You have the left side cap removed. Bag that cap and its shims for now to maintain what was there -- and set it aside as the "No. 1 Side". Now -- there is an oil line from the oil pump forward to a fitting at the rear of the block. This line passes oil through the oil lead stud through the head to the tappets. Disconnect this line so you don't "rip it out" as the block is moved. For a picture showing all the oil pump lines and what their functions are, go to the JD-H Restoration Site (below), scan across to ARTICLES 2, and from the drop-downs, select OIL PRESSURE ISSUES -- a totally new posting. Next, a total of nine fasteners secure the cylinder block in place, four on the bottom, and five into the main case. Remove ALL of them. The next task is to begin moving the block forward while AT THE SAME TIME rotating the flywheel in a "running" direction, that's top forward -- this to bring that No. 2 journal up where you can gain access to it. THE TRICK HERE! That block must be raised up in front as it is moved toward the front of the tractor. There are small blocks in the front end support frame that you must overcome. And so a pull-N-pry or carpenter's pinch bar comes in handy to sort of raise the front of the block (from beneath) while at the same time using another instrument to pry the block forward. A helper for you is wise so as to make sure the crankshaft is rotated bringing the right side journal UP (not down). Confused? Give me a call if needed (830) 627-0430 (PatB)
