Carb leaking at strainer cap
Mark Poss
05-11-2008 10:51:34
I have a dltx-10 carb that leaks at the srrainer cap. it has a washer on it but no matter how much i try to recenter it or try different torque settings it still leaks. Any ideas? Thanks for your time Mark.
CalJim
05-11-2008 22:00:27
 Re: Carb leaking at strainer cap in reply to Mark Poss, 05-11-2008 10:51:34
You might try using two gaskets under the cap, mine leaked until I did that. CalJim
Duane Larson
05-11-2008 12:32:20
Mark,
The brass tops are particularly susceptible to cracking. The ones provided by Deere have a much shorter nut - reproductions of the originals are available from Roberts Carb - www.robertscarbrepair.com - in either brass or steel, and likely other carb repair places.
One other possibility - one time I got some kits which had the seat that the top threads into mis-threaded at an angle so the top did not touch the cast iron bowl uniformly. They were all leakers.
Mike M
05-11-2008 11:26:12
Is it leaking around the center nut ? I take and put some permetex sealer under the nut. If you use a piece of paper you can get it smeared under there. If leaking at the outside make sure the casting is true. I clean them up with a file. Use the gasket from JD that fits into the recess of that cap too. You may have a cracked or warped cap too ?
