JD 4020 starter problem
howard childres
05-11-2008 07:58:04
I just bought a 4020 JD.. Had a few problems, mainly broken cables and lights.. It had been sitting for a 3 or 4 years. However when I put a battery in it and primed it, it's diecyl, it started and ran well.
It has been converted to a 12 volt system. NOW THE PROBLEM-- My son said that he had heard you could start one without the ignition key being turned on.He tried this and it started.. However, ever since I have a problem with it. When you turn it off the starter keeps running and sometimes the starter won't pull full power. Sounds like it doesn't have enough power coming to it to engage the selinoid.. Did starting it and running it without the switch being turned on cause a problem ?
If so, where would the damage most likely be??
Any suggestions or help will be appreciated. My e-mail address is [email protected].
Rudy in TX
05-11-2008 09:11:08
 Re: JD 4020 starter problem in reply to howard childress, 05-11-2008 07:58:04
I just had the same problem with my 4010 starter. It has been converted to 12 volt. I changed the starter drive and the selenoid and put it back on the tractor. The starter engaged the flywheel and hung there until the starter barely turned . I finally got the battery unhooked and tried to restart but starter was shot. took it to repair shop. The starter drive needed a stop on it that I did'nt put in it to keep it from going in to far. When it hung and ran the battery down it burned the wires on the brushes in two. They fixed it[very reasonable] and it is fine now.
howard childress
05-11-2008 11:27:23
 Re: JD 4020 starter problem in reply to Rudy in TX, 05-11-2008 09:11:08
Rudy, thank you for your reply. I'll have the starter checked out in the shop. Howard
Bob
05-11-2008 08:18:54
"When you turn it off the starter keeps running"
That doen't sound good at all! How long has the starter been allowed to run while the engine is running?
There's lots of possibilites, and with this conversion to 12 Volts, WHO KNOWS exactly how they wired it!!!
Could be moisture/corrosion in the starter button.
Could be chafed wiring.
Do you know if the conversion used a small solenoid ahead of the big starter solenoid?
If so, there could be problems there, then on to the BIG solenoid on the starter. It's plunger could be dirty and rusted, causing it to stick, or the solenoid's contacts could be burned and sticking. (PROBABLY the most likely problem.)
howard childress
05-11-2008 11:24:56
 Re: JD 4020 starter problem in reply to Bob, 05-11-2008 08:18:54
Bob, thank you for you help. I don"t think a second solenoid was added. I"ll check the wiring and have the starter checked out at the shop. Howard
