24t baler flywheel
ronhf
05-11-2008 07:34:06
How tight should the nut that holds the flywheel on a 24t baler be tightened? I took the cotter pin out to see if tightening it a little would take out the slight play that was in it, but it wouldn"t tighten much more. Do I just make it tight and then back off enough to get the cotter pin back in? Thanks for your help.
Old Bob
05-11-2008 13:24:58
 Re: 24t baler flywheel in reply to ronhf, 05-11-2008 07:34:06
I think there is a brass bushing that is pressed into the flywheel. Ours on a 336 baler had the wobbles, replaced it and it is good as new.
