Hydraulic Problems
Robert D
05-11-2008 06:37:27
I have a JD 310A backhoe. The problem is the backhoe hydraulics works some and the front bucket wont move at all. I checked at the fluid level and it seems ok. When it 1st started the power steering got a little tight and then the backhoe started acting up, and now there is nothing going to the front bucket controls.
Roy Suomi
05-11-2008 17:18:24
 Re: Hydraulic Problems in reply to Robert D, 05-11-2008 06:37:27
Sounds like you need to check out your pressure relief valve[priority valve] for stuck poppet valve inside the valve spool..Or a destroking solenoid test procedure..You will find many responses that I and other learned mechanics have written on these subjects in the archives..If you don't have a tech manual , you should probably get one for your machine..It's quite a complex hydraulic system used there..
johns48jdb
05-11-2008 08:01:32
add some more fluid and see if that helps. i have an old 3550 and if the oil gets low it will make the pump sound funny and the hydraulics jerky. i don't know if yours has a filter on it or not. if it does change it.
