4020 , 148 loader and a side mount sickle?
Nylon4020
05-10-2008 22:14:01
Anyone know if you can mount a side mount sickle on a 4020 that runs off front pto with a loader on it? er loader mounts such as a 148. Saw a #10 sickle mower and wondered if possible?
old bob
05-11-2008 07:26:55
 Re: 4020 , 148 loader and a side mount sickle? in reply to Nylon4020, 05-10-2008 22:14:01
I doubt you could hook up the mowing machine to the tractor because of the frame of the loader that is mounted to the rails on the tractor, and also because of the piece of the loader that is bolted underneath the tractor that connects both sides of the loader frame together. We had one of these mowing machines mounted on a 4010 and it was a easy machine to operate, no looking back.
RobMD
05-10-2008 22:19:08
Doubt it... unless you think you can rig up something. You'd be better off getting a model 350 with a 7 foot or 9 foot bar on the 3 point hitch.
Then again, you'd mash everything down and use tons of fuel when it only takes 20 horsepower to run a 7 foot bar.
Bob
05-10-2008 22:23:52
 Re: 4020 , 148 loader and a side mount sickle? in reply to RobMD, 05-10-2008 22:19:08
Around here, guys use 180 HP tractors to rake hay, just so they can sit in A/C cabs. Go figure!
