4020 generator issue?
RLFox
05-10-2008 17:20:07
My 4020 isn't charging the batteries, so I took the generator off and had it re-built. Once I re-installed the rebuilt generator I would have thought that with the tractor running there would be voltage between at least 2 of the 3 posts being used on the generator, but there isn't. Does this neccessarily mean that the generator isn't working? Or could the voltage regulator somehow cause that? I made sure to polarize after re-installing. Thanks in advance!
I don't have current going into the batteries only out, so I figure its got to be one of those two buggers gen or voltage reg.
Mike M
05-11-2008 18:55:39
 Re: 4020 generator issue? in reply to RLFox, 05-10-2008 17:20:07
Think of it as 2 12volt systems one is 12 volt neg. and the other 12 volt pos. So I's say you better have everything hooked up just like it should be or else the smoke will get out-again.
Gerald J.
05-10-2008 17:37:52
Now it seems clear you need a voltage regulator. There should be 28 volts between the big terminals on the generator when its running. There should be 24 volts between the regulator + and - terminals when the engine isn't running and 28 volts when running and charging.
Gerald J.
RLFox
05-10-2008 18:13:10
 Re: 4020 generator issue? in reply to Gerald J., 05-10-2008 17:37:52
Oh, one more quick question for you Gerald - is the ground cable that goes from the left hand battery to the frame neccessary for the charging circuit? I've removed mine, back when I was troubleshooting. Someone told me it was not needed for charging.
Gerald J.
05-10-2008 20:45:00
 Re: 4020 generator issue? in reply to RLFox, 05-10-2008 18:13:10
The ground wire is needed for all the 12 volt loads, like the lights and the fuel gauge. I don't know for sure about the generator field. I don't see a ground connection at the voltage regulator in my parts catalog wiring diagram, so that would say the field gets 24 volts so the ground at the battery middle isn't needed for charging. The parts drawing for the 24 volt generator shows the field circuit is not grounded, its wired between an output post and the field post. So the wire at the battery middle has no effect on charging, but the ordinary stuff needs it.
Remember full output from the generator is only 10 amp so it doesn't charge the batteries instantly.
Gerald J.
RLFox
05-11-2008 05:29:55
 Re: 4020 generator issue? in reply to Gerald J., 05-10-2008 20:45:00
Thanks Gerald!
Would it make sense that I could test the generator by unhooking the wires that go to the voltage regulator and then running the tractor - then I should see 28 volts it sounds like?
Thanks again Sir!
Tom 43
05-11-2008 05:58:28
 Re: 4020 generator issue? in reply to RLFox, 05-11-2008 05:29:55
Dear R.L.,
If you unhook the wires, the generator will produce very little. To check the generator by itself you would have to run a wire from the A2 generator terminal to the Positive terminal of the battery and also jumper the field terminal to the A2 terminal thus grounding the field and "full fielding" the generator. Now connect a voltmeter between the A1 and A2 terminals and you should see a lot of voltage. this is done with all other wires unhooked and should be done for a very short time as the generator is on open circuit and could be putting out 35 volts or so.
RLFox
05-11-2008 06:52:06
 Re: 4020 generator issue? in reply to Tom 43, 05-11-2008 05:58:28
Thanks Tom 43!
RLFox
05-10-2008 18:11:16
So the voltage regulator can somehow drop the volts between the two big terminals on the gen to 0? I'll sure gladly try the voltage reg next, but I'm just suprised that it can do that somehow..
Gerald J.
05-10-2008 20:45:04
 Re: 4020 generator issue? in reply to RLFox, 05-10-2008 18:11:16
The two output terminals of the generator go to the regulator. One connects to the floating chassis (has to be insulated) of the regulater, the other goes to the Gen or A terminal to go through the cutout relay to the battery terminal. If the A terminal is shorted to the regulator chassis, it shorts the generator and keeps that generator terminal voltage at zero. Ordinarily I'd expect a few volts without field excitation just from the resigual magnetism of the field poles that is necessary to cause the generator to build up voltage each time its run.
Gerald J.
