2640 water pump pulley
ToddC
05-10-2008 16:08:50
I ordered a new water pump pulley for my 2640. My old pulley clamped beween the fan and a hub that is pressed on the water pump shaft. The new pulley was a large cast pulley that has threads in it for the fan to bolt to and is meant to be pressed on the shaft. My question is: Is all I have to do is press the original hub off of my water pump shaft and press on the new cast pulley? Will the new cast pulley fit my original water pump shaft, or will I have to get a new water pump? Will my original fan fit the new cast pulley or will I have to get a new fan also? My john deere parts man couldn't help, just told me that's what it calls for, it must be a upgrade.
resting relics 1
05-11-2008 12:59:36
 Re: 2640 water pump pulley in reply to ToddC, 05-10-2008 16:08:50
Hey Todd, During my wrench twisting days with a John Deere dealer back during the 80's we saw a lot of 40 series water pumps. The change to the pulley happened shortly after the 40's were discontinued for parts but many late 40 series came with the pulley you describe from the factory. I can rebuild those water pumps in my sleep.I pulled those pulleys off with a harmanic balancer puller. Be sure to note the distance the fan is from a point on the pump so when you push the new pulley on it ends up in the right spot. Also be carefull not to push on the impeller only the bearing shaft. I agree with rebuilding the pump while it's off if it has a lot of hours on it. If your not sure how to rebuild it take to someone who does. Other wise you make break something you don't want to and end up costing you the expense of a new pump. Good Luck. John
Kevin Meier
05-10-2008 20:27:36
there are a few jd water pumps that work that way. Just make sure you measure your pulley height before you pull the hub off so you know where to put the new one back on. Also check the fan on the new one also.
good luck
kevin
ToddC
05-11-2008 05:09:03
 Re: 2640 water pump pulley in reply to Kevin Meier, 05-10-2008 20:27:36
for $155 that the jd dealer wants for thier pulley I think I will try to find a pulley like I already have on my tractor. Sounds like a expensive can of worms to open.
Mike M
05-11-2008 11:42:14
 Re: 2640 water pump pulley in reply to ToddC, 05-11-2008 05:09:03
If you do have to remove the pump and do some pressing of pulleys may as well rebuilt it too.
