Flushing Hydraulics with Deisel
FRed McNeill
05-10-2008 15:34:50
I've read where you can flush the hydraulic system with diesel. Is this acceptable on a JD400(2020) where the hydraulics, transmission and brakes all run on hydraulic oil?
Thanks
Fred McNeill
johns48jdb
05-12-2008 03:37:51
 Re: Flushing Hydraulics with Deisel in reply to FRed McNeill, 05-10-2008 15:34:50
hi f.i.t, thanks for setting me straight. i have an old ford back hoe that i flush the trans and the rear end with kero on. they aren't the reserviors for the hydraulics of course. is it all right to use kero in it. haven't done it for a while and it probably needs it again. i keep it under a shed now, but it had a rough life before i got it. i haven't priced kero in a while. i guess i look at somethings like don't even ask the price. you know its going to be high, but when your over the barrel and there isn't any other choices just go on and get it over with and don't worry about it. just had a thought. has anybody ever made up some kind of test by taking the milky oil, pouring some in a container (glass?) and pour in a little diesel or kero and see which one cuts the mess off the best. this may be a total waste of time if the kero might hurt the controls in the system, but i was just wondering what else to use. in my rear ends and trans on this old back hoe, seems like i used a high pressure washer with lots of soap once in it. is that a no-no too?
Roy Suomi
05-11-2008 17:34:23
Without starting the machine ,I would try to drain out the bottom of the rear and trans housing, to get the water from the drain plug areas first..Then raise the hydraulics all the way , shut off the machine , drain the rear and transmission ..Leaving the plugs out, After checking for children or dogs that might have strayed into the equipment range of travel,I would lower anything that was raised to expell most of the oil from loader and backhoe cylinders.remove the filters drain and reinstall.. Add fresh oil to trans/ rear housings and do it again..After 2 times , change the filters and refill again with fresh oil..Should do it..How did the water get in there?? Shifter boots ripped ??
johns48jdb
05-11-2008 04:58:14
kero might be cheaper. i just haven't seen any post here that really helps. no matter how much you flush it some will all ways remain in the system. i have an old ford backhoe and it set outside before i got it and its a mess to try to get it cleaned out with all those lines in it. i was just thinking that if you could remove a fitting off of a hydraulic outlet and circulate kero through the system while the tractor is running it might help flush it out. you would hav to keep adding kero at the rate it is going out. just pouring kero in and and circulating it throgh the system want force it all out, but will just mix it up again. it has been suggested that you need to run it to get it hot to help eveporate the water, but i don't ever see that happening. i don't know how hot a dip stick type heater for engine oil gets, but wonder if that would help. if you figure it out let us know. good luck.
F-I-T
05-11-2008 05:43:17
 Re: Flushing Hydraulics with Deisel in reply to johns48jdb, 05-11-2008 04:58:14
John:
I'm would be afraid that Kerosene will leave the precision parts far too dry. I think that you risk marring the piston bores of the hydraulic pump and spool valves. Around here K-1 still is pricier than even road #2D. I always use diesel fuel for flushing if the system is to be re-filled with oil. I always figured that if #2D was "oily" enough to lubricate diesel injection pumps, then it could be trusted to lubricate a hydraulic pump. Just my 2 cents.
Fred McNeill
05-10-2008 19:44:32
Water got into the hydraulic oil and formed a milky emulsion. I have drained most of the oil out and it has been suggested that the rest of it be flushed out with "cheap" hydraulic oil and then refilled with the "good" stuff from JD. Then I read on another thread that diesel could be used to "flush"it out. It is quite a bit cheaper.
Fred Mc.
F-I-T
05-11-2008 05:02:25
 Re: Flushing Hydraulics with Deisel in reply to Fred McNeill, 05-10-2008 19:44:32
Fred:
For flushing a system like that, I prefer diesel fuel, unless I have access to a good, thin, cheap hydraulic oil. The diesel has much, much, more lubricity than kerosene. Try to get as much of it drained out as you can, although some vestigial diesel fuel should not be a problem. Once you get it operating and up to a good hot temp, the diesel should eventually cook out and boil out the vents. But it could take a while. It might creep out of the few older seals, so just be ready for than.
HTH
Frank
johns48jdb
05-10-2008 17:42:27
why do you think it needs flushing? is it full of water or has some water in it? been lots of talk on here about how to disapate water from rear ends and hydraulic oil reserviors. i think that it has been generally accepted to flush it with kerosene and then try to heat the reservor without any fluid in it and everporate the water from the system. don't think there is any way to realy get it all out myself. if its got metal fillings in it then youneed to correct that problem first. flauhing it under those circumstances want help.
