4020 mechanical fuel prime pump.
Nylon4020
05-10-2008 13:27:36
I fortunatley have not run the '68 diesel out of fuel yet. But I probably should do a filter change. How do you know where to get the tractor stopped to make sure that the fuel prime lever will work. Something about cam lobe was mentioned in earlier post. I have tried pumping mine before and felt no resistance so was concerned it was broken. How many possible positions are there and how many of those will the pump then work with? Dont want to shut off tractor and change filters, then find I cant bleed and start tractor.
Bob
05-10-2008 13:31:13
 Re: 4020 mechanical fuel prime pump. in reply to Nylon4020, 05-10-2008 13:27:36
If you can't feel resistance to the movement of the manual fuel pump lever, the engine has probably stopped with the fuel pump lever on or near the "high spot" on it's cam.
Simply tap the starter button so the engine rotates a bit, and try again. Repeat if necessary. NO big deal.
(The camshaft rotates @ 1/2 engine speed, and the fuel pump cam has one lobe.)
Nylon4020
05-10-2008 22:07:07
 Re: 4020 mechanical fuel prime pump. in reply to Bob, 05-10-2008 13:31:13
Bob,
Thanks for the info. I had tried feeling the pump lift arm for resistance a bunch of times and think I only noticed some form of resistance once. My neighbor bought a 4020 unbeknownst to me, had run his out of fuel on the road pulling a bailer and a wagon. Thought someone was trying to steal mine briefly. He had killed the battery trying to start it before I explained that you had to loosen injector lines and bleed the fuel filter. His is a console though with glass filter. We ended up pull starting it in 6th gear. We did get fuel to flow to injector lines and I had felt resistance on his pump. Just had no battery to fire tractor. Must have been lucky to have had pump action where it was killed. Thanks again for info.
