2cyl. JD Power Unit Models
Virgil
02-19-2000 22:11:49
Just wondering how many different power units that John Deere built over the years and where I could find information on these 2 cylinder engines. Thank you
Tim (U)
02-23-2000 09:23:53
 Re: 2cyl. JD Power Unit Models in reply to Virgil, 02-19-2000 22:11:49
There's at least another one. As a kid, we had a John Deere (Model 25, I think) pull-type combine. We had a "parts" combine for it that had a 2-cylinder engine to run it. My brother and I tore it apart one to see if we could get it running.
It was a big engine - verticle cylinders with the valves in the block. It had a magneto, because I remember my brother saying, "Here old this while I turn it over". YIKES! It put out quite a punch!
Unfortunately, there was a local hot-rod club that a friend of our Dad belonged to and they came and cleaned up a bunch of scrap iron to earn money - the engine went with them.
Tim
todd
02-20-2000 09:00:19
The only ones I know of are the W power unit, which used a D engine, and the LUC which used a L engine
rod
09-29-2003 08:39:13
 Re: Re: 2cyl. JD Power Unit Models in reply to todd, 02-20-2000 09:00:19
I have an LUC that we're "fixin' up". Can anyone tell me the year of manufacture? Serial number is C 18869. Thanks
Virgil
02-23-2000 20:16:00
Tim, Learned the old "Jag from the Mag" trick early in life also. This was from a Wico magneto on a 20 horse Clark oilfield single cylinder engine that my grandad had in a central power house. It pumped about 15 wells fom a central power with rod lines to each well. This was compliment of older cousin!! They say you can pick your friends....
Enjoyed reading about your learning experience.
Virgil
ernie bowers
08-20-2000 08:02:17
 Re: Re: Re: 2cyl. JD Power Unit Models in reply to Virgil, 02-23-2000 20:16:00
Hi Virgil
Just got a model w serial #2039 power unit it came as apowers unit for a lane #1 sawmill i just bought. I know nothing about it except i hope to get it running. This is my first time with john deere all i every worked on is internationals. Any help would be apppreciated.
Thanks Ern
