LP to diesel conv. on 4010?
Justin W
02-19-2000 21:42:38
Is this conversion possible? What parts would I
need. becides the head and fuel system? Thank You for the help
Mike Aylward
02-20-2000 05:47:48
 Re: LP to diesel conv. on 4010? in reply to Justin W, 02-19-2000 21:42:38
Justin, this conversion can be done, but you will need a complete diesel engine. The spark ignition engines are only 4 -main bearing blocks and crankshafts. You will need a diesel engine, a hood (because yours is an LP), the throttle linkage under the dash and going to the diesel pump, the fuel lines, and an air cleaner and air pipes. You would probably want to convert the diesel to a 12-volt system, too. I have done this engine conversion on a 3020 and the results were good, but for the dollars spent you would be much better off just trading for a diesel to begin with. Hope this helps. Mike
