49 B ignition 6V-12V?
bighornJD
05-10-2008 05:15:19
I have searched on here and learned a lot already but time to get some opinions on my situation. I have a 47 A with 12V system and distributor ignition. No problems there. My girlfriend was recently given a 49 B. The tractor is a little slow to start and has to be cranked several times to fire but then runs fine. Im used to my A which I rebuilt that starts on the first or second spin even though the starter does strain to spin it but ive always attributed it to the higher compression pistons. I was surprised to see her B has a magneto ignition even though it has electric start and lights and is a later model. Is this original/correct and if so would it be worthwhile to swap over to distributor ignition and maybe a 12V conversion since it is currently 6V? I'm sure a good tuneup would help the starting but im thinking changing to 12V and keeping the 6V starter as many have done to make it easier for her to get it going. Thanks for any help.
johns48jdb
05-10-2008 16:27:04
 Re: 49 B ignition 6V-12V? in reply to bighornJD, 05-10-2008 05:15:19
i have a 48 b still on 6 volts. its just been cranking for 60 years that way so why change. sounds like your trying to take an ease way out, but i expect it will be harder and cost more i the long run if it doesn't crank i=any better on 12 than it did 6. i hate to see tractors that aren't left orginal, why not tune it up first and see if that helps before you do anythng else to it. i think that everybody who is doing this needs to consider the resale value on the tractor if its not orginal. a strong battery, good plugs and wires and the gas right and any tractor should crank good unless there is something else wrong with it like low compression or problems with timing or valves. if thats the problem your still going to have it even with 12 volts. ask her opinion about it first might save you a lot of trouble.
bighornJD
05-10-2008 11:00:47
I've read about quite a few people on here that are simply sending 12V to the 6V starter with no problems. I would consider doing this and switching the starter to 12V only if it failed. What else do I have to change to go to 12V? I assume i can simply change the light bulbs out for 12V and obviously the battery. I think I would rather find a 12V generator - not to fond of the alternator look. I would like to swap to a Delco distributor and run the Pertronix electronic ignition and coil. Is there anything i'm missing and should i keep it pos ground or switch to neg?
Mike M
05-11-2008 07:35:41
 Re: 49 B ignition 6V-12V? in reply to bighornJD, 05-10-2008 11:00:47
If you do the swap I would FOR SURE switch to the Delco dist. as I have seen some on 12V turn over so fast that Magneto impulse coupling kicked out which is not good. FWIW the 6 volt if cleaned up and working right and tuned up will start those B's just fine.
55 50 Ron
05-10-2008 13:31:03
You need to use the polarity that the electronic ignition needs and be sure your voltage regulator also matches that polarity.
Ford 312
05-10-2008 07:09:53
It is my understanding magnetos were used on John Deere tractors until the mid 1950 model year. I installed an alternator and Delco distributer on my 1948 B. Starts and runs better than with the magneto. Alternator costs a lot less then a generator and voltage regulator and is more reliable. Apparently a Wico distributor is not that satisfactory.
Rich Duane
05-10-2008 06:56:22
You might have a Wico XD Distributor instead of a magneto. The Wico ignition did not work as well as a Delco system. If you are changing to 12 V and don't want to alter the out ward appearance a model "50" starter and Wico Distributor along with a late model "A" generator . The better distributor is the Delco
Rich Duane.
