730 Pony Ignition
Grabatire
05-09-2008 20:41:36
While changing the push button starter switch on my 730 I noticed what appears to be an after-thought resister on the ignition switch. The thing looks like a spring that somebody bent the ends into a U shape to fit around the screws, whereas I would expect the ends of a manufactured resister to be moulded into tabs the screws fit into.
Can someone tell me what the voltage drop should be so I can check it. It may well be that somebody had to make-do but did it to specs.
I just replaced the coils so I don't want to stress them with too high of voltage. The ones I took out were fried from either the ignition having been left on too long, or had suffered a full 6 volts too often.
Thanks.
Larry in WNY
05-12-2008 09:29:21
 Re: 730 Pony Ignition in reply to Grabatire, 05-09-2008 20:41:36
FIT has a good article for installing an oil pressure switch which prevent coil burn up. If the Pony isn't running or have oil pressure, power is cutoff to the coils.
Link
I installed this on our 720 after losing 2 sets of coils.
His page is under construction, but you can probably e-mail him to get the article:
e-mail: [email protected]
Larry
Grabatire
05-10-2008 07:58:23
Thanks Brandon.
I'll check to see what the voltage drop is and if it's within the 4.5 to 5 volts I'll just keep on truck'n.
WeirdDeere
05-10-2008 00:48:07
That sounds like the right resistor to me! A wire that looks like a spring, just wrapped around the terminals like you describe.
It should drop the voltage to 4.5 or 5 volts while running.
Your coils were probably burned up by leaving the switch on.
Brandon
