52 A starter motor
n29we
05-09-2008 17:51:01
I just picked up a 52 A yesterday. It's a nice complete tractor but the starter motor spins but doesn't engage except once in awhile. I've got manuals for it on order but in the mean time I'm looking for a replacemnt. Does anyone have a name of someone who might have one or a part number so I can hunt for one myself. Thanks in advance - JimO
Mike n Mo
05-09-2008 18:30:12
 Re: 52 A starter motor in reply to n29we, 05-09-2008 17:51:01
If the starter spins but doesn't engage the flywheel, it probably just needs a new starter drive. Very easy repair, should be about $25-$30 aftermarket, available on this site for $23.92. Mike
F-I-T
05-10-2008 19:13:04
 Re: 52 A starter motor in reply to Mike n Mo, 05-09-2008 18:30:12
Also, sometimes the starter drive just needs to be cleaned and re-lubed. Since the starter sits at the bottom of the flywheel, the casting under the gear has but one small drain hole. If it gets clogged with grease and trash, the casting holds water, and it can funnel it to the gear and shaft and things can get siezed up. I'd remove it and tear it down for inspection and cleaning. You can get a free .pdf parts book on JDPARTS
It's a very simple unit.
