46 model B front bearings
Fredsjdb
05-09-2008 13:46:07
Does anyone out there have the cross reference numbers for front wheel bearings for a 46 B row crop front end. The retainer is B89R, which is still available from JD. The bearing numbers in my parts book show JD7222R and JD7259R which are no longer available. One of my bearings has a Timken number so I should be able to replace it if it isn't obsolete. Any help will be greatly appreciated. Regards Fred
d. coleman
05-10-2008 18:28:19
 Re: 46 model B front bearings in reply to Fredsjdb, 05-09-2008 13:46:07
pat, thanks also, i to have had problems with finding certin bearings at my deere dealer. my parts person seems very knowlegable, but why wouldnt they know to search the way you mentioned? i feel funny about telling them how to do there job, by saying " try dropping the R ". thanks anyway. d. coleman
Fredsjdb
05-09-2008 19:35:37
FIT and Pat, Thanks for the replies. My dealer here in Lake City has two of the items and they are reasonable. I will order the one they don't have in stock. Regards Fred
F-I-T
05-09-2008 16:07:47
Yeah, Fred, Pat's right about those bearing numbers. I just checked and the JD7222 is around $16 at Deere, and the JD7259 is $11. You could probably get them both to cross at a place like Motion Industries, but for that price, Deere is probably a one stop for you.
Also, on JDPARTS, if you ever have to search really longer part numbers that are other than bearings, when you get something like an AR123456R, you have to drop the trailing "R" there, too. The "C" coders apparently had some troubles converting the old database, but for the most part they did a good job. It does take a bit of sifting sometimes.
Frank
