420U and 420W front loader interchangeability
bill420u
05-09-2008 11:28:53
Would a JD loader (model unknown) for a 195? 420W fit a 1956 420U? Both tractors are 4 speed. Is there anything else I should be aware of?
Dave H
05-09-2008 18:24:51
 Re: 420U and 420W front loader interchangeability in reply to bill420u, 05-09-2008 11:28:53
I know you can never get enough hydrqulics, but the 420"s hydraulics on mine run the #35 loader just fine.
boler76
05-09-2008 16:57:39
How do you go about driving a hyd pump from the front of the crank on your 56 420w? I dont seem to be able to figure that out Thanks in advance. Jim
bill420u
05-10-2008 06:24:53
 Re: 420U and 420W front loader interchangeability in reply to boler76, 05-09-2008 16:57:39
There is a shaft bolted to the pump and connected to a modified crankshaft pulley by means of a spline connection similar to a pto setup. That's what turns the front mounted pump.
Dave H
05-09-2008 15:35:24
Bill - I recommend that you start with what kind of loader it is. Here is what the manual on the JD model 35 hydraulic loader states in part - I left out all the models that are not an issue.
The JD 25 hydraulic loader has been designed to fit the following tractors: 420, 430 and 40 seruies row crop utility (W) and 420, 330, 430, and 40 utility series.
The model plate is located on the upper right frame of my #35. If you look and see it don't get all warm and fuzzy if it says Ser 1 behind the model - that is the Series 1.
CPeter
05-09-2008 15:00:28
I have an after market loader on my 420U that came off a 420W. The mounts are similar but DIFFERENT. The U is longer from front of tractor to rear axle and the front mount is slightly different. I made and adapter for the front and the rear was sort of adjustable. It cam out pretty good, but I got it about a 1/2" too far forward and had to redo the front mounted hydraulic pump drive shaft.
third party image
CPeter
Rusty Wheel
05-09-2008 11:58:12
I had a front loader that came off a 420. I believe it was a model 35. I got it to go on a 40-w but the rear axel brackets wouldn't fit. I sold it 3 years ago. I would imagine it will fit if the axels are the same..... ...rw
