Gator Blades on a 72 deck
F-I-T
05-09-2008 09:05:11
Anyone here use the mulching blades on a 72" Deere deck? The blades with the serrated trailing edge. I have a lot of leaves to chop up in the fall and all through the winter when I mow and I saw a set of these at a good price on eBay and thought I might give a set a try. Do they tend to throw stuff any more/less than the standard blades do? They look like they might really suck the horsepower.
third party image
buickanddeere
05-09-2008 18:35:48
 Re: Gator Blades on a 72 deck in reply to F-I-T, 05-09-2008 09:05:11
One story about gator Blades is..... .....They are supposed to provide some lift and don't wear out as fast when used over sandy soil vs. a full lift blade.
Looks may have something to do with their sales appeal?
Dave H
05-09-2008 15:39:17
Frank
My gator blades for the El Toro Z Turn are laying on the shelf. I did not see any improvement and as stated they had less vscuum and less blow and the grass coming out seemed the same to me. However I run an open discharge chute.
Have never tried them on leaves - don't have any trees that big.
They may just be zn awsum combination with the mulching kit - I don't know.
F-I-T
05-09-2008 15:57:28
 Re: Gator Blades on a 72 deck in reply to Dave H, 05-09-2008 15:39:17
I'm going to try them without mulch baffles first. I would like to avoid installing/removing the baffles based on the seasons. We shall see. I will try to return with a full report in a few months.
Mike Aylward
05-09-2008 14:54:10
Frank, I use them on a 54" deck with a straight discharge (no bagger) and wouldn't use anything else. In taller grass they take a LOT LESS power and do a better job of distributing the grass. When I replaced the last set of blades all the dealer had were original blades. I used them one day and went to another dealer that had the gator blades. I am sold on them. Mike
F-I-T
05-09-2008 15:02:48
 Re: Gator Blades on a 72 deck in reply to Mike Aylward, 05-09-2008 14:54:10
Cool. I ordered a set so we shall see.
Mike M
05-09-2008 10:18:44
I have tried the Gator Blades on JD decks of 38" and 54" your results can and will vary depending on grass type and time of year. Dad also uses them on his Ventrac 60" Things I have observed are less sucking up of mulch as I mow near flower beds and they ACTUALLY seem to use LESS HP and GAS and they do seem to work better in dry conditions and on leaves in the fall. Does JD offer the mulch baffle kit for the 72" ? we put on one our 750 with 60" and it chops up the leaves good.
F-I-T
05-09-2008 10:49:43
 Re: Gator Blades on a 72 deck in reply to Mike M, 05-09-2008 10:18:44
Yes, they do offer a mulch kit. I might try that, too. When I mow in the fall and winter it is generally very, very dry. Sounds like it might be a good choice.
edj856
05-09-2008 09:08:39
They're designed to recirculate the cut grass clippings back in front of the blade to chop it up smaller. They're great at mulching leaves, but have very little lift or vacuum.
F-I-T
05-09-2008 09:25:55
 Re: Gator Blades on a 72 deck in reply to edj856, 05-09-2008 09:08:39
Sounds like what I need to try then. Thanks for the reply!
