Electric Start for an Unstyled D?
Loren in Iowa
05-09-2008 06:23:13
For anyone who has reached the point where they would rather not hand crank their D, has anyone seen any clever ways to convert their unstyled D (ours is a 1930), to electric start? Will any parts from later Ds work?
Rob in UPrMI
05-09-2008 09:14:43
 Re: Electric Start for an Unstyled D? in reply to Loren in Iowa, 05-09-2008 06:23:13
I use a belt and my styled B to start my D (1927). It always started easy, but all of a sudden nothing. If I pull start it or use the belt it takes off right away. I am thinking my impulse spring is weak. It runs great when it starts
F-I-T
05-09-2008 07:53:34
You might laugh, but years ago, maybe '68, a local guy had a spoker "D" that he had at the local shows. He rigged a start cart using a Briggs 5hp, and a narrow flat belt, with a spring tightener. He would sit it in line with the clutch pulley, lay the belt on, fire up the "pony" motor, engage the "D" clutch, start the "D", then pull the clutch, shut off the B&S, and remove the belt, and he was good to go. It worked like s charm and he started many "D"s at the shows that way. You just have to work at the ratio to the pulleys to get probably 150 rpm to the pulley. I'm guessing at the speed, but I took that from a 70D which specs the cranking engine to turn the diesel at 200 rpm during cranking. I would think 150 would do a "D" just fine. He did have a lever that had two spikes that jammed in to the ground to hold the cart in place. It was a sight.
jd40an
05-09-2008 07:49:17
Back when my Dad used a '29D for his "big" tractor, I learned to start it by hand when I was about 10 yrs old! Dad always kept the "ole D" in near perfect tune, & it very seldom took more than two turns for it to start. If your tractor is set up/"tuned" properly & primed correctly it will start very easily every time! And yes, the later unstyled "D" (3 speed) can be converted to electric start by simply using the needed parts from a styled "D".
usetabesteve
05-09-2008 07:38:50
The starter setup for a G would probably work if you can find a ring gear to fit the D flywheel.
Get yourself a John Deere H and use a belt, or almost any tractor and a chain. It takes two people to use the chain start method though. A lot of places a pickup truck is enough tow vehicle to start a tractor.
Coltond202
05-09-2008 07:05:05
Everyone I know gets a 19 year old kid like me to start it for them.
