Cleaning 1946 B Air Cleaner
JD Gimpl
05-08-2008 18:49:59
Ok,
What are the suggestions on how to clean the air cleaner. Mine had water in it and everything floated up into the wire mesh.
Thx Gimpl
johns48jdb
05-09-2008 15:49:11
 Re: Cleaning 1946 B Air Cleaner in reply to JD Gimpl, 05-08-2008 18:49:59
i'll probably get jumped on for this answer, but i got mine as clean as possible and poured gas down in it and set it on fire. all the oil and grease burned out before the wire mess melted.
RICKY C
05-08-2008 19:17:20
KEROSENE OR PARTS CLEANER
JD Gimpl
05-09-2008 08:12:46
 Re: Cleaning 1946 B Air Cleaner in reply to RICKY C, 05-08-2008 19:17:20
Do you have to dismount the whole air cleaner ? I guess a fella could get a narrow can and slip it over the base with parts ckeaner in it.
Gimpl
F-I-T
05-09-2008 08:57:35
 Re: Cleaning 1946 B Air Cleaner in reply to JD Gimpl, 05-09-2008 08:12:46
Soaking the whole thing in a 5 gallon bucket of diesel fuel works well, too. Take it out from time to time and stop in onto a piece of cardboard to rattle the greasy mud loose. If you plan on repainting the assembly, hot lye water is about the best cleaning you'll do short of drilling out the spot welds and separating the mesh layers, cleaning each of them, then reassemble.
