JD 1010 Top cover shifter assy
jwhart
05-08-2008 11:57:36
Ive got a JD 1010 and the gear shifter was loose and could be removed by just picking straight up. So my local JD dealer ordered me a bushing, pin for the shifter, snap ring, grease boot, and a spring to fix the problem. Now i"ve figured out where everything goes except the spring. It"s about 4" long and for the life of me I can"t figure out where this thing connects at. The diagram doesnt show where It connects. Maybe i"m having one of those dumb moments but I need help.
Thanks
Vermont John
05-11-2008 04:06:41
 Re: JD 1010 Top cover shifter assy in reply to jwhart, 05-08-2008 11:57:36
I have a shop manual for the 1010. If you like I can send you a fax of the section on the shifter. It shows a spring and may help.
Osage
05-08-2008 16:37:00
I'll go look in the morning to make certain how its connected. It is connected inside the upper bell shaped dome to keep the shift handle in neutral. I think it crowds the shift handle to the left side but I'm not sure about that either.
Osage
jwhart
05-09-2008 11:20:49
 Re: JD 1010 Top cover shifter assy in reply to Osage, 05-08-2008 16:37:00
Well I see a slot on the right hand side of the housing. I'm thinking is goes from there to the hole hole next to the mounting bolt. I'll try that when I get off work today.
Thanks for you help.
JW
