3010 hyd pump question
RedEd
05-08-2008 11:10:07
I have a John Deere 3010 that the hyd pump squeaks. With the pump disconnected, no squeak, so I know it�s the pump. However, when the pump is under load (example: 3pt moving up or down, steering tight turns) the squeak stops. This squeak occurs in gear, or in park. My first thought is a bearing, but when it stops under load??? Any thoughts?
S.C.
05-08-2008 20:15:52
 Re: 3010 hyd pump question in reply to RedEd, 05-08-2008 11:10:07
It is probably the coupling. Does it look like two disks? The 20 series used a different style coupling that doesn't squeak. It will work on the 10 series. Last time I bought one, it was around eighty dollars. Probably a lot more now.
DONMYEIL
05-08-2008 14:18:59
That noise came along with the price tag. It is the stroke control valve spring rubbing the guide. You might try turning the destroke screw down and then back up, this will sometimes turn the spring and make it quit, but dont hold your breath.
Mike M
05-08-2008 11:42:56
May just be normal ? Those pumps can make all kinds racket when destroked or sitting idle and run quietly under full load.
