720 D fuel tank question F-I-T or Clooney
Tracy Redd
11-03-2003 00:00:37
I was sanding the fuel tank and I notice a big casting fitting with 2 threaded holes on bottom of the tank. One for fuel line that came out side of casting. On the threaded hole on bottom of casting, does that hole uses for fuel segiment bowl or cut off valve or something else?
It have two fuel lines, one line that goes from top of the head (injection cover) to the top of fuel tank. the other line that goes from bottom of tank to transfer pump. Is that right? Can you e-mail the photo of fuel tank assy?
E-mail address is [email protected]
Thanks
Tracy
Clooney
11-03-2003 03:05:33
 Re: 720 D fuel tank question F-I-T or Clooney in reply to Tracy Redd, 11-03-2003 00:00:37
Tracy, you didn't mention if your tractor is an early pony start, late pony start, or electric start�.. It doesn't really make a difference on the parts but only on when the later auto bleeding system was factory installed� Even then some of the earlier tractors were retro-fitted.
~Basically that big tank fitting & extra lines were add later in the 720D's life & on the 730D when an auto bleed pressure regulator was installed on top on the fuel rail. ~Check your E-Mail as I sent you a parts breakdown of the early & late fuel system parts�..
[email protected]
