Ceramic coating on manifold
Mark Poss
05-07-2008 15:50:11
Has anyone had their manifolds or exhaust pipes ceramic coated? And if they did how did it hold up, where did you get it done, and what did it cost? Thanks for your time. Mark.
Jason_1936
05-08-2008 17:17:49
 Re: Ceramic coating on manifold in reply to Mark Poss, 05-07-2008 15:50:11
I just had a muffler for a 1950 Model B coated in flat black by Moore Power Coatings of Waverly Nebraska, (402) 786-2887. They did a terrific job, two coats to ensure any light areas were covered. The cost wasn't bad either, $42.00 including tax. For exhaust pipes, which I will do at some point I was told to estimate $1.00 per inch of pipe length. They can also do a chrome-like finish which looks really nice but not my style for tractors. I will definately take more work to them.
JDBert
05-08-2008 06:45:31
Did the manifold on my 4840- gained some horse some fuel efficency and lost alot of temp especially under the hood and at the turbo- aint cheap. Give Terry a call best way to get ahold of him he does mainly truck manifolds but does tractors as well. Coating is done on the inside and outside, manifolds are flowed benched and ported. I gained 96 CFM on my manifold when it was done.
http://www.fulltiltperformance.com/
Mike M
05-08-2008 05:35:58
I had some aluminized and it holds up nice. My cousin worked at a machine shop with equipment to spray weld up shafts and they could also do this with that equipment. That spray weld repair on shafts held up great too !
d. coleman
05-07-2008 18:43:12
years ago i had a set of motorcycle head pipes done at Jet Hot, worked great, the company was in Mississippi at that time, dont know if they are still in business.
jdhbag
05-07-2008 18:06:46
Go to www.specialtyexhaust.com. I have talked with a couple of people that like his process.
showcrop
05-07-2008 18:00:42
Hi from what I see its very popular for performance engines because it insulates and it seems to be very durable too they also coat pistons to protect the tops from too much heat. Try googling Swain's coatings
RobMD
05-07-2008 17:28:24
it'd chip off.
